B16a2 intake manifold help!
Old May 18, 2002 | 03:35 AM
si foo's Avatar
Default B16a2 intake manifold help!
Hey guy got B16 swap into my civic. Everything seem's to be fine I'm using a B16a2 intake manifold there's two engine harness left that has nowhere to be pluged. One is behind the motor it's a small two wire harness and the other one should go to the B16 intake manifold but because I'm using a B16a2 manifold there's no sensor on it. What should I do with these harness? Do u guys leave the harness alone( the one that's behind the motor)? What should I do with the intake harness?..........thanks
Old May 18, 2002 | 06:26 AM
E-AT_me's Avatar
Default Re: B16a2 intake manifold help! (si foo)
there is one plug you don't use AT ALL on the si harness, it's a small 2-wire plug. i think white? behind the intake manifold. but about your other one, i'm not sure. is it for the MAP sensor?
Old May 18, 2002 | 11:55 AM
si foo's Avatar
Default Re: B16a2 intake manifold help! (Rexman)
not sure if it's for map sensor. the jdm intake manifold has the sensor but not the B16a2 so it just hanging now. Anyone has any idea what to do with this plug check engine light is on. Reading code one (oxgyen contents) and for some odd reason the motor redlines at 7k.........help theanks
Old May 18, 2002 | 01:02 PM
civicguy's Avatar
that is the intake temperature sensor.i got the same problem like you,but when i ask the guy who had it before,he says he never use it,oxigen content code could be what kind ecu your using or oxigen sensor is going bad
Old May 18, 2002 | 01:19 PM
si foo's Avatar
Default Re: B16a2 intake manifold help! (civicguy)
I'm using a pw3 ECU and if the oxgyen sensor is bad where is it located at?
Old May 18, 2002 | 01:28 PM
AudioXtremes's Avatar
on your exhaust mani.
93grayeg
Feb 26, 2015 02:47 PM
Dead CIVIC
Jan 30, 2008 02:53 PM
Morhpeous
Jun 11, 2005 09:06 PM
ultimatehonda
12
Jun 3, 2005 11:24 AM
Emoson
Aug 10, 2004 05:35 PM
