Dfferences between b20b and b20z
Old Feb 5, 2007 | 06:30 AM
blackhope121's Avatar
Default Dfferences between b20b and b20z
i read here that the b20b had 126 hp and the b20z had 143hp
but here on hmotorsonline they are saying the b20b has 143 hp
http://www.hmotorsonline.com/s...it=25
is this a mistake or is there somthing different
Old Feb 5, 2007 | 06:39 AM
Syndacate's Avatar
Default Re: Dfferences between b20b and b20z (blackhope121)
I believe that the B20B was '96-'98 and the B20Z was '99-'01.
With what I'm pretty sure (2.4L) is a K24 from '02 on.
Neither were VTEC and the 96-98 B20B was rated at 126bhp while the '99-'01 B20Z was rated at 143bhp.
Old Feb 5, 2007 | 06:47 AM
so hmotors made a mistake then right
Old Feb 5, 2007 | 06:48 AM
Syndacate's Avatar
Default Re: (blackhope121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhope121 &raquo;</TD></TR><TR><TD CLASS="quote">so hmotors made a mistake then right</TD></TR></TABLE>
Hey man, I've been trying to avoid confrontation lately, so right now I'm not one to start pointing fingers 'n ****, but it sure as hell looks that way.
Old Feb 5, 2007 | 07:59 PM
DuVaL rAcEr's Avatar
as far as i know there is no such thing as a jdm b20z. they are all jdm b20b's so technically they are not mistaken, if im not.
Old Feb 5, 2007 | 08:29 PM
NOFX's Avatar
H-T White Ops
Default Re: (DuVaL rAcEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuVaL rAcEr &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know there is no such thing as a jdm b20z. they are all jdm b20b's so technically they are not mistaken, if im not.</TD></TR></TABLE>
True, but hmotors is selling '96-'98 B20Bs, so in that year range it should be the lower ratings anyway.
Old Feb 5, 2007 | 08:44 PM
USDM.LOVE's Avatar
Default Re: (NOFX)
What do you have to do to make a b20 v-tec? Because they are cheap to get.
Old Feb 5, 2007 | 08:50 PM
Eran's Avatar
HT White Ops
If their B20B's have 143hp, then they are the JDM 99+ B20B, which is the equivalent of the USDM B20Z.
Old Feb 6, 2007 | 07:38 PM
i think there was big problem a while ago with them rating them as 143hp and selling the 126hp motor. really it just comes down to a gamble if your buying a b20 from an importer because of this. check the head it should be mark with the year it was made.
Old Feb 6, 2007 | 07:40 PM
Default Re: (USDM.LOVE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM.LOVE &raquo;</TD></TR><TR><TD CLASS="quote">What do you have to do to make a b20 v-tec? Because they are cheap to get.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1676914 theres more to it than what it seems.
Old Feb 6, 2007 | 09:27 PM
spock_rocker's Avatar
memoryFAB.com representative
95.5-98 JDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
99-00 JDM B20B are 9.6:1 PHK compresion pistons
Rated at 146hp
97-98 USDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
99-00 USDM B20Z are 9.6:1 PHK compression pistons
Rated at 146hp
Old Feb 6, 2007 | 09:45 PM
JDMish's Avatar
Default Re: (spock_rocker)
some nice info... is it worth replacing the p3f pistons with the phk's????
Old Feb 6, 2007 | 09:54 PM
inline4's Avatar
Default Re: (JDMish)
no, you're better off getting a b20z with the pistons in it already to start with. you won't have to mess with all the work and sourcing the p3f pistons.
Old Feb 6, 2007 | 09:56 PM
JDMish's Avatar
Default Re: (inline4)
i have a b20b motor already and want to know if it's worth putting in the phk's? will i feel a difference?
Old Feb 7, 2007 | 09:34 AM
^ yes you will feel about a 20 hp difference... get the ITR spec pistons if your going to go through all that.
Old Feb 7, 2007 | 07:58 PM
JDMish's Avatar
^don't have that kind of money to spend
Old Feb 13, 2007 | 11:33 AM
Equilibrium's Avatar
* B A N N E D *
lol, if you're going to upgrade pistons, you're spending a 150 dollars either way on rings and pistons- do as the man says and get yourself some compression.
Old Feb 13, 2007 | 04:56 PM
one bad dx's Avatar
Default Re: (Equilibrium)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">95.5-98 JDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
Rated at 146hp
Rated at 126hp
Rated at 146hp
What would the marking be on the head for a 99-00 spec head? I know with the GSR or B16 you can find P72 or PR3 on it somewhere in the casting. I'd just like to know cause I'll be picking one up very quickly.
Thank you in advance.
Coolero
16
Aug 5, 2024 09:22 PM
Stephdavis18
Apr 16, 2006 11:06 AM
Alex_G
Jan 31, 2006 04:28 PM
Patron
Jul 1, 2005 07:42 PM
88B20CRX
Jun 25, 2003 07:46 PM
