dizzy/coil/ignitor/main relay/fuel pump interchangability?
Old Feb 4, 2007 | 11:24 PM
budomove's Avatar
Default dizzy/coil/ignitor/main relay/fuel pump interchangability?
I have a 91 civic std, and was wondering from what models can I use these parts?
88-91 civic dx ignition coil work?
how about the dizzy?
Old Feb 5, 2007 | 07:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
Any DPI distributor will work - STD, DX, or LX. I'm fairly certain the coil from any model D-series will work (DPI, MPFI, OBD-0, OBD-1) but I could be wrong about the latter.
Old Feb 5, 2007 | 05:13 PM
mahatma's Avatar
Default Re: (DaX)
any igniter, fuel pump, & main relay will work also
Old Feb 5, 2007 | 10:30 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (mahatma)
the dx and std distributor is, for sure, different from the si and hf distributor. they are not interchangeable, and youll see with the plugs that this is the case, because hf and si distributor have an extra sensor, the tdc/crank sensor, which the dx and std do not have.
the main relays are interchangeable for sure.
i hazard a guess to say that the coil and ignitor are the same, as the distributor on the si and hf share the same form factor as the dx and std , but im not certain they are the same part number.
and the fuel pump, i believe, is the same in both cars.
fitbkeco
Aug 2, 2013 01:04 PM
sorta2
11
Jan 14, 2012 05:23 PM
crxben
Oct 25, 2006 02:44 PM
Badass240SX
Dec 5, 2004 08:37 PM
Red_Si
Jul 5, 2002 04:57 AM
