2004 Civic
I need to know if anyone has any info on the type of motor. I know that it has a D17 but Im not sure if they made different types or if they did if one type is better than the other.
Engine codes:
01-05 Civic
EX: D17A2 VTEC
LX, DX: D17A1 Non-VTEC
HX: D17A6 VTEC-E
Best of the 3: the D17A2 found in the EX's. But if you DON'T have an EX, and want VTEC... all you have to do is swap heads.
01-05 Civic
EX: D17A2 VTEC
HX: D17A6 VTEC-E
wow dude. search. go to wikipedia and you can read up all about the d17.
giving us your civic year is only part of the info we need... what model? the dx/lx models have a d17a1 (~114HP/non-vtec). ex models have d17a2 (~128HP/vtec).
Thanks alot for your help I found some info on the d17 but it was just general stuff and I could not find the diff. types but mine is an ex so thanks to yalls vast knowkedge I can figure out what direction im going to go.
Check the FAQ's next time, bud. This info. has been covered multiple times.
http://en.wikipedia.org/wiki/Honda_D_engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">D17 Series Engines (1.7 Liters)
D17A1
* Found in:
o 2001-2005 Honda Civic DX/LX/VP
+ Displacement : 1668 cm3
+ Bore and Stroke : 75 mm X 94.4 mm
+ Compression : 9.5:1
+ Power : 115 hp @ 6100 rpm & 110 ft·lbf @ 4500 rpm
+ Valvetrain : SOHC
+ Fuel Control : OBD-2 MPFI
D17A2
* VTEC
* Found in:
o 2001-2005 Honda Civic EX
+ Bore and Stroke : 74.98 mm X 94.4 mm
+ Compression : 9.9:1
+ Power : 127 hp @ 6300 rpm & 114 ft·lbf @ 4400 rpm
+ Valvetrain : SOHC VTEC-E
D17A6
* VTEC-E
* Found in:
o 2001-2005 Honda Civic HX
+ Power : 117 hp @ 6100 rpm & 111 ft·lbf @ 4500 rpm
D17A7
* Found in:
o 2004-2005 Honda Civic DX
o Uses CNG (Compressed Natural Gas)
+ Compression : 12.5:1
+ Power : 100 @ 6100 rpm & 98 ft·lbf @ 4000 rpm
+ Valvetrain : SOHC
D17A1
* Found in:
+ Valvetrain : SOHC
D17A2
* VTEC
* Found in:
D17A6
* VTEC-E
* Found in:
D17A7
* Found in:
+ Valvetrain : SOHC
Youmissme
Honda Civic (2001 - 2005)
Apr 12, 2014 06:31 AM
sloem2
14
Aug 1, 2007 11:38 AM
