front sway bar
Old Feb 4, 2007 | 03:40 PM
ludesterS's Avatar
Default front sway bar
Ok, im doing some road racing on my 92 h22 lude i have kyb agx on proggress 2inch drop springs and proggress(27mm) rear sway bar..... i would like to upgrade the front ether tanabe(30.4mm) or suspension techniqes(25mm) what would be better? or any other brand?
Old Feb 4, 2007 | 07:46 PM
1GPlusSH's Avatar
Default Re: front sway bar (ludesterS)
Wow, 30.4mm?? That sounds like plow city to me. Have you checked with anyone that has put a front swaybar that big on a lude? I'd personally go for the smaller one unless you have crazy oversteer.
Old Feb 5, 2007 | 04:56 AM
hu's Avatar
hu
I have a Neuspeed on the front and progress adjustable on the rear. Most people will tell you not to fool with the front, just do the rear.
Old Feb 5, 2007 | 08:58 AM
f22builder's Avatar
I have ST on lower front and rear..I already had neuspeed upper front and rear.
When i first put the ST on and only had front upper tower bar i noticed my *** end was doing horrible things. The front of the car would take the turns flat but my rear end would drag. If that makes sense.
THe good.
Great handling.. good parts (make sure you get the endlinks with the bar) my OE bent within two or three weeks.
the bad.
my rear lower bar tore out of the subframe. the mounting point is not very strong. I had a custom mounting plate bolted on...I beleive the pprogressive bars come with a new mounting plate (highly recomended)
Overall car handles like a champ
And my car is built for ups and downs and lefts and rights
hope this helps
ribal_gh
Suspension & Brakes
Apr 5, 2014 02:27 PM
ImPuLsIvE
Sep 3, 2007 10:49 AM
520lbGIANT
Suspension & Brakes
10
Aug 26, 2007 02:43 AM
spoonlongblock
Honda Civic (2006 - 2015)
Aug 6, 2006 05:59 AM
Diversion
Mar 1, 2002 04:11 PM
