battery issue please help
Old Feb 4, 2007 | 02:02 PM
trianglegreg's Avatar
Default battery issue please help
My battery light came on like two days ago, and my battery is good its either the alternater, or some sort of electrical issue, pretty much whenever my rpms go above 4000rpm the battery light turns off then the second i shift out of gear and the rpms drop it comes back on. Does this sound like an alternator problem and if so is there a way to check it?
Old Feb 4, 2007 | 02:05 PM
dr_latino999's Avatar
Default Re: battery issue please help (trianglegreg)
Alternator, when you spin it up it's able to overcome internal inefficiencies.
Old Feb 4, 2007 | 02:18 PM
Default Re: battery issue please help (dr_latino999)
so you think its definately the alternator? just wondering how does an alternator go bad anyway if the bearing and belt are completely fine.
Old Feb 4, 2007 | 02:20 PM
The internal bits can wear out, in technical terms the brushes and the windings. Also the Voltage regulator can go bad causing it to overproduce shortening it's lifespan.
Old Feb 4, 2007 | 05:48 PM
cool thanks for the help
Bryan Franco
Honda Civic (2006 - 2015)
May 10, 2017 04:29 AM
90HondaDA
Oct 6, 2010 01:59 PM
mayfly
Jun 28, 2009 04:34 PM
haywyre
Oct 9, 2008 12:27 PM
vietkangta
Oct 21, 2007 09:20 PM
