toda C's too aggressive?
Old May 17, 2002 | 09:36 PM
ITRfaithful's Avatar
Default toda C's too aggressive?
i notice everyone here who has toda cams have As or Bs but rarely any Cs... are they just too aggresive to use... i don't might a rough idle or whatever, just as long as i can kill other folks with ease. is it possible to use toda Cs in a ls/b18c1 vtec, if my block is reinforced, and i have upgraded toda valvetrain? help me out!
Old May 17, 2002 | 09:44 PM
Mr.Integra's Avatar
Default Re: toda C's too aggressive? (b18newbie)
i also would liek to hear more info about toda c's
Old May 17, 2002 | 09:49 PM
Chris's Avatar
Default Re: toda C's too aggressive? (Mr.Integra)
For daily driving.. Yes I think so.
Old May 17, 2002 | 10:06 PM
TodaSi's Avatar
Default Re: toda C's too aggressive? (Chris)
I like em
To me they are the same as the B's just with better top end 7000+
They do require more tuning, more up keep and more attention to detail then say the Spec A's do.
Old May 17, 2002 | 10:11 PM
Mr.Integra's Avatar
Default Re: toda C's too aggressive? (TodaSi)
for daily driving isn't it the same as B's.... i mean they idle the same and everything.. like toda si said, its only more aggressive in the top end.
Old May 18, 2002 | 03:42 AM
ttt
Old May 18, 2002 | 04:27 AM
Razor's Avatar
why do they call these cams "vtec killers"?
Old May 18, 2002 | 04:50 AM
Reid's Avatar
Global Moderator
Default Re: toda C's too aggressive? (Razor)
VTEC killers and Spec C's are not the same cam.
Go read all about the differences at http://www.todaracing.com.
Old May 19, 2002 | 05:59 AM
specceg6's Avatar
The C's are no problem for daily driving... I have them in my daily driver with TWM ITB, idle is not that bad, tuning is the key with the B's and C's... I think the trade off is worth it , there's no better feeling then pulling up to a corvette C06 at the street races and take his $$$ b/c he's a non believer ....
Old May 19, 2002 | 06:28 AM
Michael Delaney's Avatar
Default Re: toda C's too aggressive? (specceg6)
how did you solve the throttle link sticking problem with the TWM's and what filter did you use with them?
Old May 19, 2002 | 06:31 AM
Default Re: toda C's too aggressive? (Michael Delaney)
oh yeah, I forgot, 48 or 51mm? , did you use a hood scoop and if so, where did you place it?
sorry for the questions on the ITB's and getting a little OT from the original thread but I wanted to get some info from an ITB user. Tony the Tiger is thinking of switching to these on his beast and has some questions on them compared to the Hayward ITB's that C-speedracing had posted up here.
Old May 19, 2002 | 11:05 AM
specceg6's Avatar
To solve the throttle sticking issue all I did was use a helper spring from the throttle link to a little mount I fabbed out of aluminum and bolted it onto to a 10mm hole on the strut tower....
As for a filter I started using the ITB's with no filter, just open but dust/dirt can be a problem... Lip helped me out by giving me the last of the TWM fiberglass air box's that they don't make anymore and it fit like a charm in my CX... It didn't fit his car cause of the big brake master cylinder.... It comes with a 2 1/2 opening so I ran a 2 1/2 pipe to a iceman elbow to the wheel well with a HKS power flow filter...The car runs a **** load better now that it's getting cold air instead of under the hood hot air off the firewall...
Old May 19, 2002 | 12:02 PM
b19coupe's Avatar
You might want to consider bumping up your compression if you are planning to run the Toda C's. You will also need adjustable cam gears to tune them in order to take full advantage of their potential. A stand alone fuel management system would not hurt either.
Old May 19, 2002 | 12:43 PM
GokuSSJ4's Avatar
Default Re: toda C's too aggressive? (b19coupe)
to gaim good amounts with the spec C what CR would you consider on 91octane ?, maybe running hondata or aem management system.
Old May 19, 2002 | 01:06 PM
TodaSi's Avatar
Default Re: toda C's too aggressive? (Spoon1)
11.5-12.5 has been the norm for compression.
I've been hearing good things about Hondata with the Spec C's.
Old May 19, 2002 | 01:16 PM
GokuSSJ4's Avatar
im still debating which cams to go with next , but i always been a fan of toda's.
GokuSSJ4's Avatar
how much tunning is there envolve with the spec C
mugeneghatchie
Mar 25, 2007 07:43 AM
Blanket Jackson
30
Sep 29, 2004 11:12 AM
Turbo R
Aug 15, 2002 07:36 PM
ITRfaithful
May 18, 2002 04:42 PM
Black R
Feb 2, 2002 09:10 AM
