Crankshaft TDC??
An easy way to tell its at TDC is to take the #1 cylinder plug out, stick a long screw driver or something of the like. Turn the crank until the piston is at the highest point which should push the screw driver up. If the timing marks don't line up, correct as needed. Good Luck
Thats just an easy way to do it, I always make sure to line it up on the mark thats on the block next to the crank pulley.
Xemu
28
Apr 22, 2007 01:56 PM
