Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
'03 CRV, Engine codes p1166 and p1298
Old Feb 3, 2007 | 02:32 PM
jwbrockman's Avatar
Default '03 CRV, Engine codes p1166 and p1298
My mom has an '03 CR-V that's just thrown these two codes. The p1166 seems to be the front o2 sensor, which is understandable, since the car has almost 90k. We plan on replacing that ASAP. But the other code is a bit more cryptic - it's and Electric Load Detector circuit high voltage code. I'm not sure if this is something that can be caused by the bad O2 sensor, or an unrelated problem. Both codes did pop up simultaneously though, we'd never had any CELs before this since new, which leads me to think they must be related. If anyone has any experience or advice on this code it is much appreciated.
Josh
Old Feb 4, 2007 | 04:52 AM
Ross 2.0's Avatar
In a Junkyard near you.
The ELD code i wouldn't worry about.
Just go and buy a OEM (NOT aftermarket) sensor and install it, then take it to the dealer and get your computer reflashed
Old Feb 5, 2007 | 05:36 PM
thedarkmark's Avatar
Default Re: (ScruffyTheJanitor)
so like a denso $$ ? I have the same prob. wouldn't mind getting a bosch o.e type to save some money.
where would u reccomend getting one?
thanks
kaivorth
Honda Civic (2001 - 2005)
May 28, 2014 03:26 AM
~sp33~
13
Jan 14, 2009 12:30 AM
R-81DC2
Apr 4, 2007 05:16 PM
raphael
Aug 8, 2006 05:44 PM
95civicracer
Nov 21, 2003 10:29 AM
