O2 sensors? Stick with stock or others ok?
Old May 17, 2002 | 07:14 PM
Casey's Avatar
Default O2 sensors? Stick with stock or others ok?
Should i stick with a stock O2 sensor or will a bosch sensor work fine? Im pretty sure the bosch is less expensive and if it does the job just as well i cant see spending money just because its OEM. Thanks
Old May 17, 2002 | 07:36 PM
Chiovnidca's Avatar
Default Re: O2 sensors? Stick with stock or others ok? (CWTypeR463)
OEM seem to last longer, but aftermarket definitely cost less.
Old May 17, 2002 | 07:57 PM
Kamin's Avatar
Default Re: O2 sensors? Stick with stock or others ok? (Chiovnidca)
im using a bosch
works great
i aint paying that much for a honda
its rediclous.
Old May 17, 2002 | 11:05 PM
90civichbsi's Avatar
Default Re: O2 sensors? Stick with stock or others ok? (KAMiN)
i wouldnt get bosch anything for a honda, but to each his own. i would go w/ a denso or ngk o2 sensor
Old May 18, 2002 | 09:10 AM
Casey's Avatar
Default Re: O2 sensors? Stick with stock or others ok? (90civichbsi)
wheres the best place to buy a denso or ngk 02 sensor? thanks
Old May 18, 2002 | 12:10 PM
Jared's Avatar
Factory is very expensive, but the Bosch works great, and the Bosch single wire universal is only $18.
Old May 18, 2002 | 12:15 PM
Perfectionist's Avatar
I tried the generic Bosch sensor first. One lasted 2 weeks, the next one didn't seem to work at all. Got my money back and bought the Honda sensor at hparts.com for $106. Been fine ever since, and that's about a year now. Just my experience. YMMV
Honda Fit
May 2, 2010 05:29 PM
RedEj8
16
Feb 11, 2007 07:35 PM
rdeezy25
May 16, 2005 12:31 PM
autopc8
Apr 11, 2003 12:35 PM
ILOVEGIRLS
Nov 5, 2001 01:05 AM
