how to remove plastic shroud/cover to the wiper linkage windshield washer lines
Old Feb 3, 2007 | 10:41 AM
tewee's Avatar
Default how to remove plastic shroud/cover to the wiper linkage windshield washer lines
any help would be great, thanks
Old Feb 3, 2007 | 01:56 PM
OG undercover's Avatar
Default Re: how to remove plastic shroud/cover to the wiper linkage windshield washer lines (tewee)
curious, for what?
Old Feb 6, 2007 | 06:45 PM
tewee's Avatar
Default Re: how to remove plastic shroud/cover to the wiper linkage windshield washer lines (namechangeR)
one of my washer nozzles aren't dispursing washer fluid
wanna check if there's something in the lines
cuz i already check the output side of the nozzle
Old Apr 13, 2007 | 12:47 PM
energ3tic2's Avatar
turn the clips on the engine bay side 90 degrees , some of them might be under a rubber seal..pop out the clips on the window side with a small screw driver. try not to pry on anything to aviod damaging the plastic or the window. with some maneuvering it should come right out
Old Apr 13, 2007 | 02:04 PM
digitalVinyl's Avatar
The round clips that are on the shroud itself are a bit of a trick, but do come out. You are going to need 2 watchmaker screw drivers (I prefer these since they are small). One fine one, and one beefier one (you need the bigger one so you can get the needle nose pliers in).
Pry up gently withe the fine screwdriver, and add the second screwdriver to pry it a bit more, stick the pliers in and don't bend the clip itself, kid of apply a teeter totter motion to it (I put a towel under the pliers and used it as a fulcrum).
I don't know if that was clear enough, but if you have problems getting those little bastards out just shoot me a PM.
Good luck with it!
globy123
Jun 7, 2009 10:22 AM
Dkahn18
Jan 3, 2009 09:18 AM
89hatcher
Mar 5, 2007 08:51 AM
littlecivic
Jul 1, 2002 11:29 PM
citanest
Oct 27, 2001 04:51 AM
