91 hatch frt turn sig lens-How do you remove W/O breakin off the tabs on backside?
Old Feb 3, 2007 | 09:31 AM
tlkolrod's Avatar
Default 91 hatch frt turn sig lens-How do you remove W/O breakin off the tabs on backside?
Headin out to the junk yard in search of turn lens (front) How the heck do those come off since it is NOT with just the obvious two screws. Some weird clippy thing in the back that put up a good fight till they snap in the 20 degree temps (bummer)
Whats the trick? Gotta take the entire headlight out dont ya. There has got to be an easy way out!!! Speak up fellas!! Thanks Toby
Old Feb 3, 2007 | 09:40 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 91 hatch frt turn sig lens-How do you remove W/O breakin off the tabs on backside? (tlkolrod)
You just have to be verrrrrry careful when taking them out. Slide them carefully towards the front of the vehicle after undoing the screw holding the lens to the headlight bracket.
Old Feb 3, 2007 | 09:46 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: 91 hatch frt turn sig lens-How do you remove W/O breakin off the tabs on backside? (wiZCo)
the 91's have a single screw that attaches a plastic arm on the back side of the light housing to the fender of the car. remove that single screw, and pull the light toward your chest if you are in front of the car. the clips are actually just little slider clips that dont screw in or anything. once you unscrew that screw, it should slide right out. the clips will easily break before the headlight housing will, so dont worry about them unless you need them on your car.
VTECROAR96typeR
Nov 20, 2010 02:36 PM
trimagna
Aug 31, 2007 07:23 PM
danno33
Dec 28, 2006 01:43 PM
Mr.Speed
May 1, 2005 12:19 PM
petrv
May 6, 2003 10:11 PM
