92 accord TPS.
I am in dire need of a Throttle position sensor (TPS)
92 honda accord
4dr DX
2.2l
I have recently Dropped a lot of money on a transmission rebuild and a few other minor adjustments to figure out my Transmission/shifting problems. Come to find my TPS is nt throwing a code but reading OFF. Reads 0.5 at idle.... As far as alldata says it should be 0.2 at idle.
I have read on this site that it should be .4 at idle and lik 4.3 WOT...... I am at a loss. ALLDATA is a car program and i got the readout form my transmission mechanic. PLZ help in any way
I would like to purchase one or if anyone has any tech tips on getting those crappy bbroken bolts off, OR (much more important) How to properly mount the new TPS.
Thnx in advance
Broke *** NEWB mechanic
92 honda accord
4dr DX
2.2l
Thnx in advance
Take a Dremel tool with a cutoff disk and cut a slot in each bolt head on the TPS. You can then remove them with a screw driver. Some of the Preludes had bolt on TPS's. Maybe someone here will chime in as to which one.
secondgen
Mar 20, 2007 04:13 PM
