Need Help After Search
Well i was coming home and went to start my car, but no go. When i put my key in, it sort of sticks, and you have to wiggle to to get it to turn. Finally, when I get the key the first position, the radio and everything come on fine. When i turn the key, however, the lights all dim and i hear a buzzing sound. I used the search function and have checked the grounds. Could it be the starter? For weeks it has been very slow starting my car, it will slowly crank for a couple seconds. What kind of starter can i use, i read that all the b series should be the same, so a manual integra perhaps? I had to pop the clutch o get home and dont feel like parking on hills for a while.
[Modified by mafioso102, 9:35 PM 5/17/2002]
either that or your starter is slowly dieing on you. if its a 4th gen, you'll have to find out what kind of started it came with, cause there were 2 diff ones honda used. i think they were mitsubs and nippondenso(spelling?). correct me if im wrong though,
although, this could also be the fault of the battery or the alternator
