rear brakes problem
My driverside rear brakes in particular is squeeling again. I just replaced the pads & rotors about six months ago(both sides) and then 4 months after that, the rear brakes on the driver's side started making that annoying hi pitch noise(pad life indicators), the pads were done. I checked the calipers visually and nothing seems to be wrong. So I replaced it and NOW its doing it again and my pads are almost done, AGAIN!....the passengerside rear brakes are and had been fine. Someone pls. help me out. I'm guessing its somewhat stuck or the calipers dont just grab off at all. I'm about to replace them soon but i'l wait for advices.
The piston bore is either seizing or the guide pins are also seized... You will need to also inspect the rubber condom that covers the piston bore for leakage...
Regards
Teken
Regards
Teken
put some antiseize. and remember im talkin bout the rear brakes and i dont think i got that "rubber condom" on the rear brakes(not sure tho but last time i checked, i saw none, verify which u are talkin about.)...only in the front
thanks for the help.....
can you help out more w/ some pics.......
so that i can see exactly which ones i should be playin round with....
thanks
thanks
Did you use factory Acura pads?
if not you will get squeaking.
