wisconsin (FEB.07') FS,WTB,TRADE,
another month. this one colder then the rest. you know what to do.
WTB
88-91 civic/crx floor mounted passenger side seat belt clicker. asap
88-91 civic/crx charcoal canister
88-91 civic/crx si stock air box
aftermarket d-series header with 1 o2 bung
good condition z6/y8 head with vtec sylinoid and dist.
Modified by HxCforever at 6:35 AM 2/4/2007
WTB
FS- Updated today!
FS....
4 wire o2 sensor-$20
b-series hydro halfshaft-$30(sold)
b-series cable halfshaft-$30(still available)
b-series hydro drivers side axle-$25
2 b-series passengers side axles (need boots)-$10
RCI 5 gallon fuel cell. part # rci-2050D. You can use either the -8an lines or i'll include a set of -6an fittings. I also have about 20ft. of -6an russell's steel braided lines and an external fuel filter-offer
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 obo well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
CNC Reverse throw clutch pedal with master cylinder- For all you guys that want to convert your car to true hydrolic this is what you need. All you do is just run your -3an line straight to your clutch slave cylinder-$70
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $450
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something
-$25
more random junk...
Stealth style GSR intake manifold. Inside of it has been port/polished-$30
ecu's-...
obd0 88 Pm6-$10
obd0 91 pm5-$10
obd0 91 pm9-$10
obd0 91 pm9-$10
Tons of miscellanious EF parts, headlights, tail-lights, corner lights, cluster, resistor boxes, etc. etc. Ask me chances are i have it. I'm too lazy to take more pics. Selling for dirt cheap.
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
88-91 Civic/Crx steering column with tilt-$20
b-series upper and lower alternator brackets-$20
7/8" civic/crx brake master cylinder-$10
b-series hydro slave cylinder-$10
1 wire o2 sensor-$5
(2) b-series rear T brackets from 99-00 si-$30 each
(2) resistor boxes-$10 each
b-series fuel rail-$10
b-series fuel regulator-$5
90-93 DA integra hubs-$15
92-95 Civic front shock forks-$15
(2) lower b-series power steering brackets-$5 each
88-91 Civic/Crx radiator fan-$10
94+ integra radiator fan-$10
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Also for sale...
MINT cf hood for 96-98 civic-$200
Anyone interested in any parts PM me
Modified by theinfamouskonrad at 2:53 PM 2/9/2007
FS....
-$25
more random junk...
ecu's-...
obd0 88 Pm6-$10
obd0 91 pm5-$10
obd0 91 pm9-$10
obd0 91 pm9-$10
P72 stock rods $10
1 wire o2 sensor-$5
Windows-
$35 each!
Also for sale...
4 LS mesh with Michelin XGT V4, 2 tires are bald because idiots mounted it wrong.
stock 99 gsr shifter, will include leather shift **** (**** has little wear) best offer
off 99 gsr, i do have code. 80 obo
120 w/ spark plug cover, also have stock cover
off 99 gsr, best offer
buy this now or someone else will!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HxCforever »</TD></TR><TR><TD CLASS="quote">another month. this one colder then the rest. you know what to do.
WTB
USDM EJ1 in the Madison area has a Z6 head for $50
WTB
Selling 17inch Rs Limited Concept Pros for $300. Will need new tires. The rim is in mint condition and the lug nut bolt is 4x100 and 4x114. Pm me if intereted. The pics are provided in the link.
http://www.hondamarketplace.co...68498
WTB
88-91 civic/crx si stock air box</TD></TR></TABLE>
I have these. pm me if your intrested.
WTB
http://www.hondamarketplace.co...77129
f/s stock air box,tube,resonator box
clear corners
front brake rotor
all for eg
clear corners
front brake rotor
all for eg
**** i meed gone cause i'm moving. everything i no longer need so basicly i'll take anything for it
88-89 civic hatch std black front bumper. bare
jdm oem b16a obd0 header with 2 working o2 sensors
white. 88-91 civic hatch tail gate with broken glass. no rust at all.
jdm Y1 tranny. 4th and 5th gear syncrose are burnt the fuckout. the rest of the gears are mint. buy this for the rare 1st 2nd and 3rd gears you cant find anywhere else for your old b16 tranny
Prelude for sale. http://www.hondamarketplace.co...91678
anyone have stock suspension or cheap aftermarket stuff for a 88-91 Civic/Crx. I need both stock rear control arms as well. If interested i can sell you some k-sport 36way adjustable suspension with function 7 rear control arms for cheap if you provide me with some. Pm me need them by tomorrow though.
updated!! Stuff is getting sold fast!!
For sale... Everything is in Mint tip-top shape. Less then 2000-2500 miles on everything. I purchased all brand new back in october and only got to drive my crx less then a month before the weather changed and these parts sat ever since. I'm going a different route for next year and i have no use for these things. Please don't pm me asking for trades because i don't need anything. Only thing i may be willing to work a deal out with is a gt42R turbo or bigger...... k here you go....
Fluidyne half sized radiator for 92-00 Civic's. Perfect working condition, comes with slim fan-$220
Endyn breather kit-$120
MSD Pro Billet distributor setp. Comes with dizzy, magnacore wires, coil, and ignition module. The dizzy is obd2 but i also have a MSD obd2-obd1 conversion harness as well. Best ignition setup you can buy!! -$350 for everything.
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it! Stock Type r LSD with 4.40 Final drive. It also comes with the shift fork, and an ACT throw out bearing. -$1300 well worth it. Located in Milwaukee, WI. Depending on where your from i'm will to meet up. Add up the synchros+other parts + labor and your basically getting the tranny for free. Check out gear-speed.com for more info.
BRAND NEW Worldwide Alternator for obd0-obd1 b-series. Lifetime warranty as well from advanced auto parts. Also has aem pulley on it. $90
RCI 5 gallon fuel cell. part # rci-2050D. You can use either the -8an lines or i'll include a set of -6an fittings. I also have about 20ft. of -6an russell's steel braided lines and an external fuel filter-$150 for EVERYTHING!
Mr. Gasket 68mm throttle body, comes with map sensor and gsr throttle bracket. You can use this on ALL b-series.... it has both holes on the throttle rotor so you can pull the cable with the gsr throttle bracket or from the other way with the bracket on the intake manifold. Mazworx also sells these on h-t -$200
Selling my COMPLETE turbo kit!! Everything was purchased brand new, made 550WHP with this setup and has less then 2000-2500miles on it!! Setup is...
Garrett GT35R Turbo .63a/r 4 bolt exhaust flange
aem 4" filter
3" downpipe (has tiny tiny dent about the size of a nickel on the bottom, nothing major, not cracked etc. won't affect anything)
Custom made ramhorn turbo manifold
tial 44mm v-band wastegate with 13lb blue spring
2 1/2" beautiful intercooler piping all tig welded. Bends are mandrel. Stainless steel.
Tial 50mm bov
Turbo has -6an russell fittings for coolant lines, as well as the -an lines to run it. Also has -4an oil inlet fitting with restricter and -10 Functiion7 outlet fitting with -10an steel braided line to connect to oil pan.
All turbo boots are included with all t-bolt clamps
Johnny racecar intercooler 3" thick
Pipes are gauranteed to fit like stock in 88-91 Civic/Crx's. I do believe you should be able to get them to fit in 92-95 civic's as well and possible teg's and ek's with slight modification.
$2000 takes it all!!!! Don't waste your $ on a greddy kit when you can get the best one $ can buy for less!
TurboXS high-performance dual stage boost controller-$160
BFG drag radials 225/50/15's. Have life left in them-$100 for both
polished antifreeze catch can-$25
dc sports dual bend shifter for 88-00 honda/acura's-$30
PLX M-300 Wideband. Only used it after my car was dynoed. Less then 800miles on it-$220
Python 871xp paging alarm system. Also included are power door locks-$175
REAL CF spark plug cover for b-series vtec heads-$35
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300 PRICE LOWERED to $250!
JDM CTR cams, have normal wear, no scratches on lobes-$300 for both
Taylor battery box-$50
ALSO HAVE FOR SALE BUT NOT PICTURED>>......
Vafc1 Vtec controller-$80
99-00 SI front lip-$25
Mint 99 b16a2 swap(complete)-$1400
Anyone interested just pm me. Located in Milwaukee, WI. Depending where your from i'd be willing to meet up. I have a bunch of other stuff that i will post fs later, but this is most of the good stuff.
Modified by theinfamouskonrad at 3:36 PM 2/18/2007
aem 4" filter
Tial 50mm bov
<FONT COLOR="purple">
<FONT SIZE="10"> FS: TESTING WATERS </FONT>
I’m selling my hatch with clean title
either shell or else complete with GSR swap
Pictures will be up by this weekend
See package pricing </FONT>
$1,500-----------------1991 Honda Civic Si Red
$60---------------------Sears Diehard Battery with warrantee
------------------------------OEM radio/tap unit
------------------------------OEM rear speaker pods
$480--------------------RSR exmag II exhaust (NEW never seen rain or snow)
$120--------------------JKBO obd1 conversion harness (the original H-T who started it)
$150--------------------EF si wiring harness converted OBD1 plugs, o2, knock & vtec
$80----------------------Hasport EF B series shift linkage (no cut and weld)
$350--------------------Hasport EF B series billet mounts
$175--------------------Hasport EF B series hydro conversion kit
$43---------------------OEM DA speedo cable (new)
$29----------------------OEM DA throttle body (new)
$40----------------------OEM DA rear transmission mount (NEW)
$100---------------------Napa DA axles (NEW with lifetime warrantee)
$12----------------------ES shifter stabilizer busing
$75----------------------EF billet MC brace (not installed)
$180--------------------OEM HX 14” rims with center caps & tires
$600 --------------------Wings West RS 6 piece kit (new not installed)
<FONT SIZE="3"> $3,994------------------estimated cost</FONT>
I bought this car, was from CA. I’ve had it for 3yrs and have driven it less than 500 miles. With the current GSR swap it has less than 200 miles. This is my toy car; I drive it 3-5 days out of the year. Everything works great & sunroof is flawless. Still on OEM suspension, shocks & springs are great & still feel super soft as my 00 civic sedan. The wiring was done by Kevin Smalls aka Keebler65. Cleaned, cut, soddered, taped, shrink wraped & taped agian. @ 160,000 miles on body. No rust, dents or paint fade
Interior is 9.5* outside is 9*
The only thing wrong with it is broken ignition from 2yrs ago when someone broke into my garage & tried to steal my car. The car was unlocked so no damage to door locks. I have all parts needed to replace including new keys & plastic cover.
<FONT COLOR=" green"> PRICE:
Cost me $3,994 - - - - <FONT SIZE="5"> cost you only $2,300 for everything</FONT>
Only thing you need is DROP IN B series swap & ecu, no need for harness.
If you want it with my mint gsr setup included with new exedy clutch & flywheel $4400
if you want the apexi turbo kit with HSK manifold (no FMIC) with less than 1,400 miles on turbo kit it will be extra $1,100... mint!
Minus from price if you don’t want:
-$100 for all Hasport mounts & shift linkage
-$100 WW kit
-$50 HX rims
</FONT>
as you can see... it's dusty but MINTER than most midwest civics I've seen.
I've had it for 4yrs and never ever washed it.
Why?... cause I never had too, never drove it in rain, snow.
it just collects dust.
the valve cover i got from a local memeber.
Let me know what you think... again just testing waters.
-$100 WW kit
-$50 HX rims
</FONT>
WTT- 16" AutoX tires (Hankook Ventus Rs2 Z212) for 15"
I have (4) 225/50 R16 Hankook Ventus Rs2 Z212 tires I bought last March used for about 8-9 local autocrosses and summer daily driving last year that I can no longer use due to a new rim diameter & wanting to compete in a stock class. They are in good shape and I'll post pix later. The outer edge is the most worn part of the tire but these are assymetriacal-meaning they can be flipped on inner/outer side. Purchased, Mounted and one was patched by Big Bear Tire in Oconomowoc and they were removed by a local garage in Hartford, WI in fall. These tires have great (low)noise levels,wet performance and comfort, good grip.
Specs-> https://www.edgeracing.com/tire/1522/
What I am looking to trade for is a comparable set of 15" tires. Falken Azenis 615 or the same 'kook in a 15".
I'll sell the tires if there's interest but I am looking to get an even trade first.
Local transaction preferred so you can see the tires and I can see your trade.
Is it just me or do these monthly threads keep getting shorter?
EG Hatch OEM unpainted front bumper - 200
obd1 vtec wiring harness - BO
EG Interior Pieces - Tell Me What You Want, I Might Have It
EG Blower Fan & Heater Core - BO
-4an oil feed line with russel anodized fittings - 30 OBO
This is the last of it guys, help me get clean off this Honda addiction.
BEST OFFER ON EVERYTHING
NO LOWBALLING
ALL PICS in sig link
Fully Adjustable TEIN SS Coilovers 6k $650 ($1k new)
H23a1 Engine Harness complete $75 pending sale
H23a1 parts harness make an offer (will sell individual clips)
EL Guage Cluster SI Auto no box $80
Main Relay pulled from running car OBO
H23a1 Cams OBO
OEM Gathers Factory Deck w/ cd changer unit $85
OEM 4th Gen Passenger Fender $60
JDM H22a Auto Tranny $250 45k
Prelude S standard guage cluster $35
ExplicitSpeed Performance H22a mounts $250
OEM 4th gen Passenger fender (small dent) OBO
JDM H22a Dizzy internal coil $75 (same as H22 and h23)
4th gen S-Si rear rotors Slotted Drilled (no name) OBO
