2.2L B20 Re-Build (Pics)
Old Feb 3, 2007 | 04:18 AM
VVV's Avatar
VVV
Default 2.2L B20 Re-Build (Pics)
So I decided to put together some new and left-over spare parts from my old 2.2 crower long rod kit that blew 2 years ago, ditched the 89 setup for 2007 season. Project still in progress, will update more... but for now, enjoy the pics.
Erm, the k24 motor in the first pic is another project lol
Old Feb 3, 2007 | 06:25 AM
Brick Top's Avatar
Default Re: 2.2L B20 Re-Build (kstmotorworks)
very nice what caused the motor to give last time?
Old Feb 3, 2007 | 06:30 AM
ImportechPerformance's Avatar
Default Re: 2.2L B20 Re-Build (brick top)
Ha! on the last pic it looks like the cams are bleeding..
Are those RM cams?
Old Feb 3, 2007 | 11:52 AM
VVV's Avatar
VVV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">very nice what caused the motor to give last time?</TD></TR></TABLE>
oil pump failure.
Old Feb 3, 2007 | 11:55 AM
VVV's Avatar
VVV
Default Re: 2.2L B20 Re-Build (ImportechPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportechPerformance &raquo;</TD></TR><TR><TD CLASS="quote">Ha! on the last pic it looks like the cams are bleeding..
Are those RM cams?</TD></TR></TABLE>
yea, bleeding moly...
No, cams aren't RM... btw, wonder why their website is down?
Old Feb 3, 2007 | 12:41 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kstmotorworks &raquo;</TD></TR><TR><TD CLASS="quote">
oil pump failure. </TD></TR></TABLE>
i'm sorry to read that. best of luck this time
Old Feb 3, 2007 | 02:40 PM
tallguy's Avatar
very nice G/L on the rest of the build
Old Feb 3, 2007 | 03:10 PM
Suzukii's Avatar
PSI cams?
Old Feb 3, 2007 | 06:15 PM
I*DREAM*OF*VTEC's Avatar
nice
Old Feb 3, 2007 | 07:25 PM
RedZone's Avatar
why does it look like the cams have a wear patteren like they are off to one side?
Old Feb 4, 2007 | 12:01 AM
volcom40street2's Avatar
Default Re: 2.2L B20 Re-Build (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">
why does it look like the cams have a wear patteren like they are off to one side?</TD></TR></TABLE>
Wow that is very interesting?
Old Feb 4, 2007 | 04:24 AM
VVV's Avatar
VVV
great observation...could my oil pump failure cause that? cos after the valvetrain was taken apart, a few rockers were badly worn out.
Old Feb 4, 2007 | 09:43 AM
RedZone's Avatar
I would check to see if the cam sits correctly in the head....looks like from the wear it sits off to one side... I would not be using these cams again unless you have them inspected by someone...
Old Feb 4, 2007 | 03:57 PM
1 2 NV's Avatar
is that just because the distributor caps arent on there to "position" them in the head? the cam might have fit tight in the first journal though if thats what your talking about.
Old Feb 4, 2007 | 04:53 PM
Brick Top's Avatar
thats wierd. i wonder how the cams lined up like that with the caps and dizzy in place.
Modified by brick top at 9:05 PM 2/4/2007
Old Feb 4, 2007 | 07:25 PM
Tbone's Avatar
I hope those arent actual assembly pics.. You need to oil and lub them cams alot more then that..
Old Feb 5, 2007 | 06:39 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: 2.2L B20 Re-Build (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">I hope those arent actual assembly pics.. You need to oil and lub them cams alot more then that..</TD></TR></TABLE>
+Eleventybillion.
Old Feb 6, 2007 | 08:48 AM
VVV's Avatar
VVV
yup, those are just raw pics... the build is completed, here are updated pics:
Old Feb 6, 2007 | 09:06 AM
Chugger's Avatar
whats the sroke on her 95mm what about bore 86?
nice setup what management are you gonna run with the ind. coils?
Old Feb 6, 2007 | 10:01 AM
Suzukii's Avatar
Default Re: (Chugger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chugger &raquo;</TD></TR><TR><TD CLASS="quote">
nice setup what management are you gonna run with the ind. coils?</TD></TR></TABLE>
Motec
rice_classic
13
Mar 27, 2014 08:07 AM
white da
Appearance Build Threads
Mar 5, 2008 09:24 PM
(STYLES)
Aug 8, 2007 10:49 AM
nicehatchy
Feb 4, 2007 06:36 PM
RaymondG
Jul 21, 2006 01:05 PM
