Question about gas pedal
Old Feb 3, 2007 | 12:34 AM
NguyenDC2's Avatar
Default Question about gas pedal
Well recently I just got a 2000 Accord with 55k miles on it. Yea very low miles. The only thing wrong with the accord is the gas pedal. If you don't drive the accord for like 2+ hours the gas pedal would get stuck. Like if you turn on the car and were to drive off, you would have to literally stomp on the pedal. But once you get it going and you turn off the car then turn it back on the pedal is fine. Anyone know what is wrong? Maybe some wd40? Thanks for all help =]
Old Feb 3, 2007 | 06:48 AM
361 accord's Avatar
Default Re: Question about gas pedal (IMviet)
lol yeah it worked for me
i got the same car, just with 70Kmiles, i just sprayed the outside of the throttle body with some wd40, seemed to have worked, but if u want to try, get the little red straw and spray a little down the cable maybe so it moves smoother too
Old Feb 3, 2007 | 12:31 PM
NguyenDC2's Avatar
Default Re: Question about gas pedal (361accord)
I sprayed the medal and ****, and I got to see how it works. I use lube instead of wd40.
Old Feb 3, 2007 | 04:23 PM
hondadude's Avatar
Here's the fix;
Scrub out the ring of crud around the throttle plate. NO WIRE BRUSHES
Old Feb 3, 2007 | 04:56 PM
NguyenDC2's Avatar
Default Re: Question about gas pedal (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Here's the fix;
A regular tooth brush will work?
Old Feb 3, 2007 | 05:05 PM
hondadude's Avatar
I only use Someone elses toothbrush for cleaning throttle plates
Old Feb 3, 2007 | 09:59 PM
361 accord's Avatar
is there a slight chance that by increasing the size of the throttle body passage by scrubbing out a ring of dirt will give me an extra 1horsepower??? other wise its ok cuz my pedaldoesnt stick
accord_cd5
Sep 1, 2013 08:12 AM
MrRoboto
Oct 14, 2009 03:32 AM
alb_accord
Dec 16, 2003 08:44 AM
accordblk
Acura TL, RL & ZDX
Mar 27, 2003 01:57 AM
95accordracer
Jan 11, 2003 07:43 AM
