h22 manual timing belt tensioner
Old Feb 2, 2007 | 03:50 PM
tmrtwo's Avatar
Default h22 manual timing belt tensioner
How do u do the manual timing belt tensioner? Do u use the auto timing belt tensioner parts? Any help on this topic help me out plz. I found it on faq and researched it but not sure what to use
Old Feb 2, 2007 | 03:52 PM
CGags13's Avatar
Default Re: h22 manual timing belt tensioner (tmrtwo)
did u look at 2.6's writeup?? if so what exactly are u confused about?
skunked's Avatar
Default Re: h22 manual timing belt tensioner (CGags13)
https://honda-tech.com/zero...age=8
Old Feb 2, 2007 | 03:56 PM
tmrtwo's Avatar
so what u use the auto tensioner pulley thing and tthe bolt for the auto tensioner and alot of washers?
Old Feb 2, 2007 | 04:43 PM
THC07's Avatar
Auto to Manual Timing Belt Tensioner
If you ever had to change your timing belt... you know why, its a pain. Always breaks. Like I said earlier, you don't want to pull this motor twice.
Honda part #s
14510-pt0-004 this is the Adjuster, Id suggest a Timken from AutoZone. Its only like 36$ @ honda its 68$. Auto zone can cross refrence the part #'s. The manual tensioner is on the 2.3l.
14516-pt2-000 spring 4.08$
90014-p14-A00 Bolt 3.85$
90015-pt0-000 Bolt 7.15$
900616-pt0-000 Bolt 8.48$
90140-p14-A00 Washer 3.22$
Steve and Nikki
Dec 11, 2010 02:56 PM
serjey15
Nov 27, 2010 03:50 PM
punkinbeck
Apr 22, 2007 11:27 AM
mixmastermatt
Feb 25, 2007 06:37 PM
jk11blueboi
Feb 2, 2007 06:51 PM
