Removal Of Prelude Dashboard
Hi, iv'e got to remove a prelude loom tomorrow and was wondering how i remove the dashboard, i'm not sure which year it is yet, all i know is it has a h22a as i'm going with my friend. Cou;d anyone give me any pointers as i am desperate to know??
thanks
thanks
I've taken my dash out in my 4G several times, and a 5G is probably similar.
Essentially you remove the center console, steering wheel (makes it much easier), combination switch (headlights, wipers, etc), then all the plastic pieces mouted onto the dash like the vents, glovebox, gauge trim pieces, switch trim pieces, unplug and remove any switches mounted on the dash, remove climate control, remove the gauges from the dash, and pretty much the more you strip it down the easier it will be and the better your chances of not breaking something.
Then there should be 2 bolts on each side behind little plastic covers (you'll have to open the doors
). Undo these bolts and the dash should slide out pretty easy.
sixfiveoh
Aug 8, 2009 10:43 PM
