dc sports 4-1 size collector?
Old Feb 2, 2007 | 02:49 PM
pchan's Avatar
Default dc sports 4-1 size collector?
what size carsound cat can i use for a dc 4-1 header and a greddy sp2 catback.. thanks
Old Feb 2, 2007 | 02:53 PM
Jay_Sensing's Avatar
There is a DC USDM type r, the JDM type r, and the 4-1. Which model do you have as the collector sizes are different.
Old Feb 3, 2007 | 08:54 AM
pchan's Avatar
Default Re: (Jay_Sensing)
i have the dc sports 4-1 for a 00 civic si....
Old Feb 3, 2007 | 09:55 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (pchan)
That header has a 2" collector.
Old Feb 3, 2007 | 10:38 AM
GetawayInMoscow's Avatar
Default Re: (00Red_SiR)
it will bolt to the stock cat (it should)
Old Feb 3, 2007 | 05:45 PM
LABjunkies's Avatar
i agree 2"
Old Feb 6, 2007 | 12:17 PM
pchan's Avatar
Default Re: (LABjunkies)
what about a carsound cat? 2.25??
Old Feb 6, 2007 | 01:05 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (pchan)
as long as the flange on the converter is the same as the header and cat back, you can use it (probably is). Just check the bolt spacing, if it matches you're good to go.
Old Feb 8, 2007 | 12:47 PM
pchan's Avatar
but i have to order the cat. and i dont want to have to return it if it cant fit...
anybody know if a carsound cat 2.25' piping fit a dc sports 4-1 header and greddy sp2 catback?
Old Feb 8, 2007 | 01:55 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (pchan)
I can tell you that I bought a magnaflow 2 1/2" high flow cat and it fits the stock exhaust flange, the 2 1/4" flange on the cat back I had after that and the 2 1/2" cat back I now have on the car. If the cat fit all 3 sizes of cat backs, I'm sure it will also fit the header. You should be fine...different size pipe diameters, but same flange used on each one.
jweezy225
Nov 3, 2004 02:24 AM
jweezy225
Aug 20, 2004 09:11 AM
pistol
Nov 26, 2002 11:26 AM
