TRANS WONT GO IN TO 1ST OR 2ND
does it go in any other gears? when its the car is off? or when its running? if it does not go in when its running then your clutch is not desengaging all the way and your synchronizers are doing thair job. need more info.
if you had the tranny apart you most likely put the change selector in wrong. The 1-2 fork is most likely not sitting in it properly so when you try to put it in 1 or 2 it doesnt move the fork, just take it back apart and assemble it correctly
oresama
Jul 29, 2018 08:46 PM
MattNYC
Jan 8, 2011 05:55 AM
