Wiring Questions on a 1995 GSR
Old May 17, 2002 | 04:16 PM
Drew M's Avatar
New User
Default Wiring Questions on a 1995 GSR
Anyone with a manual - I need wire colors for the following:
- Signal off of the ECT
- Signal off the O2 sensor
I need to know the O2 wire color on the CAR side of the harness, not the sensor itself (My sensor is aftermarket and all the wires are the same color). Also on the ECT, let me know which sensor it is since there are 2 (1 is not an ECT). I *think* the one I want is in the t-stat housing.
PLEASE DO NOT TELL ME ECM PIN #s!!!
Thanks In Advance!
Old May 17, 2002 | 04:51 PM
Tanner's Avatar
New User
Default Re: Wiring Questions on a 1995 GSR (Cobra)
Cobra..
on the O2 sensor you want the wire color off the ECM if so it is white/red
Coming off the ECT the wires are red/white & green/blue
is that what you needed??
-tanner
Old May 17, 2002 | 05:01 PM
Drew M's Avatar
New User
Default Re: Wiring Questions on a 1995 GSR (Tanner)
Yes but on the ECT, which is the signal wire? I guess I could check for the 5v reference but I just wanted to make sure.
Does the red/white O2 wire go all the way to the sensor or does it change somewhere along the way?
What I am doing is hooking up a temp gauge and an A/F gauge but I don't want to cut in at the ECM - I would rather do it at the sensors where I have more wire to work with.
[Modified by Cobra, 9:05 PM 5/17/2002]
Old May 17, 2002 | 05:22 PM
Tanner's Avatar
New User
ECT signal wire is the red/white
O2 sensor it is white/red all the way...
hope that help
-tanner
Old May 17, 2002 | 05:25 PM
Drew M's Avatar
New User
That's the ticket! Thanks man!
rohec04
May 30, 2009 06:07 PM
hondateg10
11
Jan 28, 2009 04:35 PM
racinskittle
Jul 6, 2003 10:42 PM
Sherm
May 23, 2003 12:47 PM
