Rear bumper Removal (searched)
Old Feb 2, 2007 | 09:42 AM
Dealer Leaf's Avatar
Default Rear bumper Removal (searched)
So ive been looking for a gen 2 rear bumper removal howto or diagram. Ive searched team-integra/net, g2ic.com and honda-tech best I found was a lil diagram and a line of text saying remove the 8 nuts on the studs in the hatch.
Any help would be great, thanks
Old Feb 2, 2007 | 09:54 AM
Default Re: Rear bumper Removal (Dealer Leaf)
NVM, theres two in the hatch, two under the bumper then the screw on the inside of quarter panel on each side.
Old Feb 2, 2007 | 09:58 AM
adamrich33's Avatar
you have two remove tailights and rear deck panel (the metal that goes under the tailights and has the key hole in it once you remove you will see about six phillip screws holding the bumper in from the top, the rear panel is accesible by removing trunk plactics to get to the 10mm bolts there are 8 i belive.
Old Feb 21, 2007 | 10:53 PM
s2k_3.11's Avatar
Default Re: Rear bumper Removal (adamrich33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">you have two remove tailights and rear deck panel (the metal that goes under the tailights and has the key hole in it once you remove you will see about six phillip screws holding the bumper in from the top, the rear panel is accesible by removing trunk plactics to get to the 10mm bolts there are 8 i belive.</TD></TR></TABLE>
Thanks for the help!
Does anybody know if the 98-01 rear bumper bolts right onto the 94-97's?
Thanks again for the help!
Old Feb 22, 2007 | 04:10 AM
ND40oz's Avatar
Default Re: Rear bumper Removal (s2k_3.11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k_3.11 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks again for the help!</TD></TR></TABLE>
Yeah, it bolts right up. I have a 98 rear on my 96. For some reason the center piece was a little to low on mine, so that had to be adjusted up for the bumper to fit flush.
Old Mar 5, 2007 | 12:17 PM
markEj's Avatar
how do you take off the "rear deck panel"?
Old Mar 5, 2007 | 12:20 PM
mike5809's Avatar
I was able to take my rear bumper off of my DA without having to take that metal peice off or the taillights for that matter (i believe).
Old Mar 5, 2007 | 02:05 PM
Jack ffr1846's Avatar
I JUST did this yesterday. To get to the screws on the top of the bumper, you may have to remove the tail lights and metal panel (2 nuts inside hatch, 2 outside on each end). I found on mine that there was so much rust that I could not use the philips fitting at all. I used a vice grip and cut each rubber gasket around each one first, then gripped them and twisted them off. There's one above the exhaust and one on the other side. The inner fender liner and mudflaps are screwed in on the sides. I can't remember if there are other ones in the licence plate area....there is on the front.
jack
Old Mar 5, 2007 | 02:30 PM
mike5809's Avatar
Default Re: Rear bumper Removal (Jack ffr1846)
Hum I will take your word for it
haha it was 6 years ago about when I took my DA bumper off, I cant remember that far back.
*Edit - now I think I remember why didnt take the taillights out/metal strip. I think I just took off the whole support with the bumper still attached. If you do that I dont think you have to take that stuff off.
Modified by mike5809 at 7:23 PM 3/5/2007
LsHoney84
Jan 10, 2008 08:00 AM
rasta420
Jan 18, 2003 07:55 AM
2001civicex
Aug 21, 2002 09:38 AM
R1020
Sep 14, 2001 03:21 PM
