OBD1 Ls intake manifold sensors
1st off, the manifold is on my b20z and im using a 99-00 civic Ex harness on this set up. The car it's going in is a 2000 Si and I plan on using a obd2b-obd1 jumper with a obd1 p75.
Maybe someone from this forum can help me with my wiring situation. I was told I need to extend the IAT plug from the Ex harness to the IAT sensor which is located on the # 1 runner of the LS manifold. That solves 1 of my problems, I can't seem to figure out which other plugs from the Ex harness goes where on this 95 Ls intake manifold. Would you guys happen to know which color wires from a stock LS harness plugs into the sensors on a LS manifold? Let me know if this makes sence
Also, I was told I wouldnt need to use the crank sensor being that i'll be using the obd1 ecu. I should have a couple plugs left over correct?
S2k Hybrid
10
Feb 2, 2007 08:29 AM
