Accord Brake Pads same as Prelude, Intergra?
Old Feb 2, 2007 | 08:16 AM
RiceFed's Avatar
Default Accord Brake Pads same as Prelude, Intergra?
My friend is offering me some free Hawk blue pads from his Integra Type R and says they will fit my Accord front calipers. Im not too sure about this though and dont have the time to actually try it.
Can anyone confirm the fitment?
Thanks.
Old Feb 2, 2007 | 08:22 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: Accord Brake Pads same as Prelude, Intergra? (RiceFed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceFed &raquo;</TD></TR><TR><TD CLASS="quote">My friend is offering me some free Hawk blue pads from his Integra Type R and says they will fit my Accord front calipers. Im not too sure about this though and dont have the time to actually try it.
Thanks.</TD></TR></TABLE>
No they won't.
Prelude VTEC and ITR use the same caliper, rotor and pads if I'm not mistaken. A factory equipped Accord will not be able to use those pads though.
Old Feb 2, 2007 | 08:35 AM
Homesickelian's Avatar
and please, for future reference, please tell us what year your car is. In some cases you won't be able to determine an answer without it.
Old Feb 2, 2007 | 08:36 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Accord Brake Pads same as Prelude, Intergra? (khunt0012)
I thought the 95-97 Accord V6 front calipers would fit the same pads as the Prelude VTEC and ITR. Am I mistaken? I could of sworn I remember this from one of those many front brake conversion threads from either here or AD.
Old Feb 2, 2007 | 08:39 AM
khunt0012's Avatar
Default Re: Accord Brake Pads same as Prelude, Intergra? (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">I thought the 95-97 Accord V6 front calipers would fit the same pads as the Prelude VTEC and ITR. Am I mistaken? I could of sworn I remember this from one of those many front brake conversion threads from either here or AD.</TD></TR></TABLE>
I could be wrong here but I'm pretty sure that's not the case. But I don't have a ton of knowledge on the V6 stuff so I'm not 100%.
Old Feb 2, 2007 | 08:42 AM
H-T Order of Merit
hmm... I'll see if I can find the thread. I may be wrong, but thats why I asked cause i thought I remember reading that before.
Old Feb 2, 2007 | 08:52 AM
philadd's Avatar
I compared the part numbers of front brake pads for a '95 Accord V6 and a '01 Integra Type R on AutoZone's website. The part numbers are the same. 4-cyl Accord is a no-go.
But it would really help to know about the Accord in question...
Old Feb 2, 2007 | 08:58 AM
H-T Order of Merit
Default Re: Accord Brake Pads same as Prelude, Intergra? (philadd)
Maybe I wasn't mistaken. but...
I haven't found the thread yet so I decided to look up the part number as well but I figured I would look on AcuraAutomotiveParts and SLHonda to compare. I couldn't find one part number that match between any of them go figure. They (92-96 Prelude VTEC, 95-97 Accord V6 and 97-01 Integra Type-R) all started with 45022 in the part number but the next two sets of numbers where different between them all.
Old Feb 2, 2007 | 09:02 AM
philadd's Avatar
I looked up a few different brands on AutoZone's site... Most matched, a couple didn't. I figure it might be due to slightly different pad composition.
As far as I can tell, the 95-97 Accord V6 is the only Accord to share the ITR's front brake pads.
Old Feb 2, 2007 | 11:42 AM
jweller's Avatar
I started looking into doing the v6 brake swap a while back and i compiled this list. All of these Hondas use the same front pad.
96 - 97 accord v6
94 - 97 accord wagon
98 - 02 accord v6
97 - 01 prelude
92 - 96 prelude vtec
94 - 01 ITR
2nd gen legend non-GS
2nd gen legend GS - apparently the same pad but dual piston caliper
03 -&gt; accord V6 auto
1st gen TL
1st gen CL v6
00 - 04 Odyssey
1st gen NSX
1st gen CR-V
this information is based on the Hawk website. which has acutal pictures with measurements on them take it for what it's worth
Old Feb 2, 2007 | 01:07 PM
philadd's Avatar
Default Re: Accord Brake Pads same as Prelude, Intergra? (jweller)
Well, I guess that settles it.
Old Feb 2, 2007 | 04:01 PM
H-T Order of Merit
Good info
Old Feb 3, 2007 | 10:19 AM
RiceFed's Avatar
Thanks for the info guys. THe car is question is infact a 95 4cyl. Im thinking its almost cheaper for me to just swap over the V6 brake calipers rather than go out and have to keep buying Hawk pads. I have a limitless supply from my friend.
The V6 calipers bolts up perfectly to the 4cyl bracket right?
Old Feb 3, 2007 | 04:02 PM
H-T Order of Merit
yes, you can use V6 calipers but you also need the caliper brackets and the larger diameter rotors.
Go to the Accord FAQ and read through the links in the Brakes section. That'll show you whats involved with upgrading your brakes to a few different setups.
Old Feb 4, 2007 | 06:37 PM
jweller's Avatar
Touring accord is right, you need the v6 caliper brackets, which are NOT available separate from the caliper from honda, or any parts store I've ever seen. So if hte calipers don't come with them, you'll probably have to go to the pick and pull
Old Feb 5, 2007 | 09:37 AM
RiceFed's Avatar
The only setback is I have powerslot big brakes on the car so if I need a different bracket then its not worth my while.
Thanks for the advice though.
Old Feb 5, 2007 | 09:44 AM
Patman's Avatar
IIRC the blue pads are rotor chompers, for a DD, most likely being an Accord, I don't think I'd use those on the street.
Old Dec 29, 2011 | 05:52 AM
AdamSiR's Avatar
sorry for resurrecting such an old thread, but can somebody tell me if the above list of front pads would also fit a jap import cl1 euro-r?
snaylor
Aug 26, 2017 05:36 AM
chri5
11
Mar 29, 2012 08:09 AM
GarageQueen213
Jul 3, 2002 01:42 PM
