B20B Vtec....What's the best ECU to run it with.
Old Feb 1, 2007 | 10:41 PM
Jeanious's Avatar
Default B20B Vtec....What's the best ECU to run it with.
Ok I have tried searching here and some other forums. I now have a B20B W/B16A head ITR Intake manifold, ITR Header, Unorthodox crank pulleys, BDL Fuel rail, AEM Fuel pressure regulator. This whole setup came from an OBD1 EG and is going into another EG. I have everything to run this but the ECU. I have thought of running a OBD1 P72 and Chip it with chrome to run the motor, but I also have a P28 that I can chip to use chrome. My question is, for the setup that I am gonna run, what ECU should I use on the car? What ECU are people running on to run their motors? I plan on running chrome and tuning it.
Also, would you guys recommend using adjustable cam gears to further tune the engine to it's fullest potential?
Any help is greatly appreciated.
Old Feb 1, 2007 | 10:55 PM
b19coupe's Avatar
Default Re: B20B Vtec....What's the best ECU to run it with. (Jeanious)
P28-cheap, plentiful, works.
Old Feb 2, 2007 | 01:04 AM
alfaaay's Avatar
Default Re: B20B Vtec....What's the best ECU to run it with. (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">P28-cheap, plentiful, works. </TD></TR></TABLE>
What he said. There's no advantage to the p72 since you have a B16 head. As for the cam gears, yes they will make a difference but you'd probably have to tune them on a dyno since the *** dyno can be fairly misleading about what they're doing to your powerband.
Old Feb 2, 2007 | 01:43 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: B20B Vtec....What's the best ECU to run it with. (alfaaay)
p28, po6 converted crome cannot be beat for the price
Old Feb 13, 2007 | 11:37 AM
Equilibrium's Avatar
* B A N N E D *
Default Re: B20B Vtec....What's the best ECU to run it with. (WHITFIELD-TUNED)
<U>Any</U> chipped ecu will work- in fact, they should all work to the highest standards if you pay for a proper tune; taking into consideration you didn't buy a junk ecu that has no ZIF socket.
Old Feb 13, 2007 | 01:45 PM
doood's Avatar
been there done that
when the ecu is chipped, it doesnt really matter which one you use
Old Feb 13, 2007 | 02:16 PM
Black R's Avatar
25 Year Member
umm.... motec?
i guess a very few will say p72 as it retains it's $cost better by having the knock board... but it's up to you. They should perform the same.....
Old Feb 13, 2007 | 05:06 PM
ghostskinner's Avatar
Default Re: (Black R)
use the p72 b/c it has the knock board
Old Feb 13, 2007 | 06:36 PM
Kataku2K3's Avatar
Default Re: (ghostskinner)
Though I don't work with straight swaps much anymore, I'm building a CRVTEC for my friend right now (using the B20Z bottom end), and I'm going to try the JDM ITR comp. I know the ECU's timing map is much more aggressive than the stock GSR (the ECU I hate the most), and it made all the difference on my buddy's stock GSR/EJ a long time ago, but I don't know how it's going to work yet. And I realize you're talking about an OBDI ECU in your case, but I'm just saying what I'm using. Normally I'd just chip a P28, but there's not a lot of programs I like for a relatively stock motor... so yea.
Just incase I didn't make it clear either... Don't use the P72. It's mapped horribly from the factory. As everyone else said, just chip a P28 with a good proggy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">They should perform the same..... </TD></TR></TABLE>
Umm, no...
Old Feb 14, 2007 | 12:24 PM
Black R's Avatar
25 Year Member
Default Re: (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">
Umm, no... </TD></TR></TABLE>
umm yes... I guess I should have clarified that this is assuming you socket and chip it using (crome, uberdata, neptune, hondata, etc) - it will run whatever program and maps you put on there.
It goes without saying that if you're going to build a motor and try to run off a stock honda ecu for another motor, that you're either cheap or stupid; most likely both.
Old Feb 14, 2007 | 02:02 PM
Kataku2K3's Avatar
Oh my bad... you are indeed right assuming you're not just talking about a stock comp.
Old Apr 30, 2007 | 01:59 PM
von_clutch's Avatar
doin a b20vtec of ma own an was readin up on this ecu thing..i hav the b16a ecu from a sir ( i think) im assuming thats a p28...was on the hondata site an i saw the s200...is it possible for me to get it and tune it for the swap maself...
Old Apr 30, 2007 | 02:04 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeanious &raquo;</TD></TR><TR><TD CLASS="quote">
If you're running B20 pistons, NO. You'll most likely end up with piston to valve contact if you are, because there isn't enough valve relief in the piston.
Old May 1, 2007 | 11:21 AM
von_clutch's Avatar
hence i wont be able to use aftermarket cams... providing that the bigger lobes will cause the valves to travel further ?
Old May 1, 2007 | 12:34 PM
Jeanious's Avatar
yeah since I Posted this I got my car tunned and removed the adjustable cam gears. I came in at 185whp with 137ft. torque Thanx to WHITFIELD RACING. If you guys are close to Upland I would highly recommend him.
Old May 1, 2007 | 12:35 PM
Jeanious's Avatar
oh yeah with ITR cams too
Old May 1, 2007 | 05:49 PM
von_clutch's Avatar
so which ecu did u use? and what setup ...another question what injectors did u use? oh wait one more u used the ITR intake manifold rite, im wondering if those have shorter runners than the b16...also if thats y ur tq is a bit low while expieriencing great hp?
Old May 2, 2007 | 02:53 AM
haveaNOSday's Avatar
will the motor lean out and grenade if you run it on a stock p28 and bigger injectors????
Old May 2, 2007 | 09:06 AM
Jeanious's Avatar
Default Re: (von_clutch)
I used the P28 Ecu running Chrome. As far as injectors they are still the stock B16 I think. I did use a ITR intake manifold and an ITR Header also. One of the reasons why my torque numbers might be lower by 5ft is cause Im using a fidanza 7.5 flywheel and a n unorthodox pulley kit.
Old May 2, 2007 | 03:03 PM
doood's Avatar
Default Re: (Jeanious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">will the motor lean out and grenade if you run it on a stock p28 and bigger injectors????</TD></TR></TABLE>
no it'll be rich and run like ****
Old May 2, 2007 | 03:42 PM
right but will the motor blow
Old May 8, 2007 | 08:15 PM
* B A N N E D *
Default Re: (haveaNOSday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">right but will the motor blow</TD></TR></TABLE>
Lean conditions promote detonation; which will blow your motor.
Rich conditions promote gas consumption; which will foul your spark plugs and oil.
Old May 8, 2007 | 08:17 PM
* B A N N E D *
Default Re: (Equilibrium)
New EJ2 civic A20A2/B series trans. best so far
1.43/6.64/9.84@157.37mph
retired 85 SMP Prelude A20A2 @30 psi Best:
1,455/6.419/9.938/143.567
vouch for Stephane "Frenchy" Beauragarde
bullyclutch.com
Pieces d'auto RENO
vouch for Seth @ Quartersports design
axle systems
CSCS
Damn, you are a dumbass with some really fast whips. I'm surprised your **** hasn't blown.
Razr2
13
Jan 28, 2008 01:54 AM
JDmspoon22
18
Sep 4, 2007 09:09 AM
lsturboswap
Apr 24, 2007 02:18 PM
loner714
Jan 9, 2007 02:43 PM
tuan...
Jul 17, 2005 07:03 PM
