ecu wiring question
Old Feb 1, 2007 | 10:22 PM
djbrandonr's Avatar
Default ecu wiring question
okay for a while Ive been tryin to locate the correct wire that supplies power to the ecu. Based on the link below, I clipped A25 and the car still started. Then I re-read the diagram and saw theres also a power wire on B1. Obviously I have yet to clip both and try to start the car, and wont for a few more days, but thats the question. If I clip both wires will the ecu not work?? Dont bother to ask why, Im sure some can figure it out. THX
http://technet.ff-squad.com/wiring.obd1.htm
Old Feb 2, 2007 | 09:10 PM
djbrandonr's Avatar
Default Re: ecu wiring question (djbrandonr)
bump, any takers??
Old Feb 2, 2007 | 09:25 PM
mafia's Avatar
try and tell me how it go's... Im intrested.
Old Feb 5, 2007 | 05:08 PM
djbrandonr's Avatar
Default Re: ecu wiring question (mafia)
okay so this is what I found. If you clip both power wires (A25 and B1)the car STILL starts. So I went to the other side of the whole circutry and played w/ the ground. If you clip A24 the car still starts. I cant remember but if you clip A23 and 24 is plugged in the car lost power over all and I had to take the batt. terminal off and replace it...something like that. But if both are clipped the car still has power but wont start. So 24 is clipped and capped off. Thats leaves 23....you know the rest
existanzcivicb20
Dec 25, 2013 03:41 AM
milanoitr
Feb 27, 2012 04:52 PM
_Cyclone_
May 4, 2005 02:17 PM
