Suspension for a DA
Old Feb 1, 2007 | 06:27 PM
1zach4's Avatar
Default Suspension for a DA
Ok well I owned a 96 gs-r for a few years and now i'm getting out of my 06 civic to get into a DA. Well i've done some searching and can't figure out what suspension fits the DA.
I'm confused on what strut bars will fit, what sway bars will fit...what actual coilovers fit because from what I can tell the suspension from another model honda/acura is what fits the DA. I just don't know which one!
Old Feb 1, 2007 | 06:33 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default Re: Suspension for a DA (1zach4)
if you still have that gsr. youll be able to hybrid a suspension w/ various parts off that DC
Old Feb 1, 2007 | 06:41 PM
1zach4's Avatar
Default Re: Suspension for a DA (MotorSpecies ver1.6)
the gs-r is long gone...i'm just looking for options for suspension.
Old Feb 1, 2007 | 08:44 PM
b16er's Avatar
Honestly dude, what the hell kind of question is this? Buy the stuff for the DA and you wont have to play 20 questions before you install a new part.
Old Feb 1, 2007 | 09:43 PM
redDAinteg's Avatar
Default Re: Suspension for a DA (b16er)
ground control and koni yellow shocks. Best modifications I made to my car so far! Hopefully the b18c I drop into my car will be just as good.
Don't go cheap, with the suspension. You'll regret that your car wont be able to handle like a champ cause you bought cheap crappy parts just to save money.
Old Feb 2, 2007 | 04:33 AM
sanjoseDA9viet's Avatar
g2ic.com is your friend
Old Feb 2, 2007 | 04:54 AM
1zach4's Avatar
Default Re: Suspension for a DA (sanjoseDA9viet)
i've searched g2ic a few times.
So am I right when I say that basically EF suspension fits the DA chassis?
Old Feb 2, 2007 | 04:59 AM
youknowimwhite's Avatar
any suspension for 94+ will fit the DA nicely as long as you get the horseshoes that connect to the bottom of the front shocks... youll have to get a lil softer suspension because the DA is slightly lighter...
but alot of companies still make parts for the DA's tein, skunk2, and other major companies make fully adjustable coilovers for them
MOST IMPORTANT: camber kits for 94+ will fit DA's except the left will go on the right and the right will go on the left... you WILL HAVE TO GET AN ALIGNMENT AFTERWARD! hope this helps
Old Feb 2, 2007 | 05:12 AM
1zach4's Avatar
Default Re: Suspension for a DA (youknowimwhite)
thanks for the info that helps a lot
98teggy-gsr
Jul 1, 2007 11:49 AM
cam3ron88
Feb 23, 2007 04:32 AM
90ED9
Oct 3, 2006 01:37 PM
slimbo
Sep 30, 2002 11:18 PM
