Dumb question
I was just wondering because ive seen people do it and it didnt grind gears and when i go to put it in neutral i feel little to no resistence
synchro matching. It doesnt hurt anything as long as you are well aware of what you are doing. You can shift 2-5 without using the clutch, but why do it when there is a perfectly good clutch pedal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">synchro matching. It doesnt hurt anything as long as you are well aware of what you are doing. You can shift 2-5 without using the clutch, but why do it when there is a perfectly good clutch pedal
You can't be a true stunna using the clutch
</TD></TR></TABLE>You can't be a true stunna using the clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">but why do it when there is a perfectly good clutch pedal
clutches are for females....real men(and cavemen) don't use them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GPlusSH »</TD></TR><TR><TD CLASS="quote">
clutches are for females....real men(and cavemen) don't use them</TD></TR></TABLE>
haha good point....
haha good point....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">No im saying going from in gear to out of gear ...to neutral. Not downshifting which obviously is better when u rev match. </TD></TR></TABLE>
wont hurt a thing. Match the sychro and pull it out of gear. If you are in gear and speed up just a tad, then let off while putting some pressure on the shifter it will damn near fall out of gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">Is it ok to take the car out of gear without using the clutch ? </TD></TR></TABLE>
if you do it without grinding, it's fine
you can pull it out of gear fine if there is no load on the motor either accelerating or decelerating.
If you put slight pressure on the stick out of gear and blip the gas it will fall out of gear. and it is completely fine to do.
So yes you can pull it out of gear with out using the clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">Shifting without using the clutch!?!?!?
BRILLIANT!!!!!!</TD></TR></TABLE>
He didn't say shift which you can do without the clutch he said pull it out of gear. which is surprisingly easy to do. If per say you were lazy.
just because you dont have enough skills to shift w/o the clutch doesnt mean its bad for the car.
i do it all the time, its a matter of preference.
You could take it out of gear without clutching.
"If the car is OFF"
Even then, I wouldn't recommend it. Even when my car is Off, I clutch then change gear. You never know if a spring will pop.
There's a reason why a clutch is a Clutch.
Definition: Clutch = Disengage one gear so you can move to another.
The question is not dumb, if you keep shifting without clutch, that may be dumb.
"If the car is OFF"
