How do you store a crank?
Whenever I store a crank I always lube up the main/rod journals with oil to keep them from drying up. Also, if you have access to and are **** about it you can store the crank on a 'crank holder'. It basically simulates the position the crank sits inside the block to prevent the counter-weights from warping the crank slightly.
Not always the case but
lube the bitch up, you can wrap it up if you're not going to use it for awhile.
If I know I'm going to be using it soon, i'll just coat it in wd-40 and stand it up under my shelves.
I have one sitting in a crank holder right now too. No reason really, just had it there and never took it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neofreak »</TD></TR><TR><TD CLASS="quote"> store it standing on end</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem »</TD></TR><TR><TD CLASS="quote">I have still yet to see proof that cranks can just warp by themselves...
If you lay one down,youll see how it sits on the counterweights and supports it.
its a %100 fact that they do.
