My coolant smells like "fish"....
Old Feb 1, 2007 | 04:16 PM
EvenStar's Avatar
Default My coolant smells like "fish"....
95 accord lx.
So I was just checking out my coolant this morning. It was full and it looked dark greenish like (I dont know if thats normal). As I put my face close to the coolant, a strong smell of fish like odor just came out. I was wondering if this is normal? Or do I need to put in a new tank of coolant?
Old Feb 1, 2007 | 04:21 PM
Homesickelian's Avatar
Default Re: My coolant smells like "fish".... (EvenStar)
You probably just have a system filled with old *** coolant. As long it doesn't have a nice brown hue you should be fine. If it does have a brown hue, it means you have oil leaking in, which can be very bad.
Best bet would be to do a coolant flush which is pretty easy. Look online but all you need to really do is drain it, and refill it up with anti-freeze at the proper mixture.
Old Feb 1, 2007 | 04:23 PM
EvenStar's Avatar
Default Re: My coolant smells like "fish".... (Homesickelian)
Hmm I might just dump this coolant out and refill it with a fresh one. I always thought coolant would always have that fresh air scent smell. Not sure what the heck my mechanic put in there since he fixed the coolant leak. Btw, what does your coolant smell like? Care to post it later?
Old Feb 1, 2007 | 04:30 PM
I don't usually smell it but I know it tastes sweet, luckily not from experience. If he fixed the coolant leak he may not have flushed it, just fixed it and added what was needed. If it was actually changed recently, that might be bad...
Maybe he's just such a comedian that he chucked a few chunks of fish in there for good luck..
Essensially though, just flush it/change it then see how it looks after a week.
Old Feb 1, 2007 | 04:33 PM
EvenStar's Avatar
nah, its been about 2 months since he fixed the leaked.
Old Feb 1, 2007 | 05:09 PM
JimBlake's Avatar
The anti-freeze part (ethene glycol) is about the same for all antifreeze brands. It's the anti-corrosion package that's different. And they don't always play nice with each other. DexCool stuff seems especially prone to getting bad when mixed with other types.
So it's not a good idea to ADD antifreeze if you don't know (for sure) exactly what brand is in there. Best to drain & rinse with clear water a few times so all the old stuff is gone.
Old Feb 1, 2007 | 05:45 PM
EvenStar's Avatar
Default Re: My coolant smells like "fish".... (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The anti-freeze part (ethene glycol) is about the same for all antifreeze brands. It's the anti-corrosion package that's different. And they don't always play nice with each other. DexCool stuff seems especially prone to getting bad when mixed with other types.
ya, thats what im gonna do lol. rinse it all the way inside and make sure its clean then add the new coolant in.
Old Feb 3, 2007 | 09:45 AM
Twixle's Avatar
ate my pixel
Be sure to use distilled water when you mix with the coolant, this will prevent coolant line buildup and radiator rusting.
Old Feb 3, 2007 | 10:08 AM
bgangsta180's Avatar
Default Re: My coolant smells like "fish".... (accord2021)
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">Be sure to use distilled water when you mix with the coolant, this will prevent coolant line buildup and radiator rusting.</TD></TR></TABLE>
my thoughts exactly
Old Feb 5, 2007 | 11:23 AM
f22builder's Avatar
Default Re: My coolant smells like "fish".... (bgangsta180)
tell your girlfriend to stop douching sp* will your radiator...sorry but i had to say it
forgive me
GeneBEllis
May 10, 2013 05:44 PM
msmithgsr2131
Feb 19, 2006 08:39 PM
GSRaCeRbOI
Jul 3, 2002 01:02 PM
Pat
Jan 27, 2002 05:12 PM
