Installed JDM dizzy now throws code 15?
Old Feb 1, 2007 | 01:36 PM
M2B4's Avatar
Default Wont start in cold weather, tried it all still nothing ne ideas?
Ok so recently my car wont fire in cold. i had a jdm dizzy laying around. so I connected yellow from ignition coil to black/yellow on the 2 pin connector dizzy. go to fire it up it turns over but wont fire and throws code 15. 15 Ignition Output Signal
missing or defective ignition output signal. any ideas?
Modified by M2B4 at 12:54 PM 2/3/2007
Old Feb 1, 2007 | 02:53 PM
prelittlelude's Avatar
Default Re: Installed JDM dizzy now throws code 15? (M2B4)
did you make sure that everything you Converted was correctly done. and if you car was hard starting in the cold i highly doubt it is the WHOLE distributor. Ususally the only thing that goes wrong in the dizzy is the ignitor. if one of the pickups goes bad the ECU knows right away.
Old Feb 1, 2007 | 03:12 PM
M2B4's Avatar
Default Re: Installed JDM dizzy now throws code 15? (prelittlelude)
i know im thinking it is the ignitor, but since i had a dizzy just sitting here i decided to try it. i think i hooked everything up right but apperntly not. so tell me what i did wrong.
heres how i did it. tell me if i did something wrong.
Old Feb 1, 2007 | 06:17 PM
M2B4's Avatar
any ideas? I found a decent deal on a new dizzy (ebay). cheaper then a new ignitor. and i need to get my white one running asap. if my jdm dizzy is messed up then im just going to buy a new one.
Old Feb 1, 2007 | 06:28 PM
WhiteBB2's Avatar
Old Feb 1, 2007 | 07:38 PM
M2B4's Avatar
Default Re: Installed JDM dizzy now throws code 15? (WhiteBB2)
so i put new rotor on my h23 dizzy put back on no code but still no fire. its like 31 deg out. so im guessing its the ignitor b/c it starts fine in warm. can ne one verify i wired the jdm dizzy right? im rdy to order a new dizzy if thats the case.
Old Feb 1, 2007 | 07:53 PM
WhiteBB2's Avatar
this is honda-tech...change the title of your topic to something that people think they can flame on ya...so they will come in and actually read this.
Old Feb 1, 2007 | 08:52 PM
M2B4's Avatar
can i take ignitor from jdm dizzy put in usdm?
Old Feb 1, 2007 | 09:58 PM
Twilightepitaph's Avatar
Yea, you can. a frind of mine did it with his h22 dizzy. Took the ignitor out of the one from the h23 that used to be in it.
Old Feb 2, 2007 | 10:47 AM
1995civicEJ's Avatar
i think that your problem is your "axle line shaft bearing belt" j/k thought i would use our made up part name.
Old Feb 2, 2007 | 03:49 PM
M2B4's Avatar
Default Re: (1995civicEJ)
lol scott. i already replaced that....no go
on a serious note. I took the ingitor from jdm dizzy put in usdm and still wont fire? any one got ne ideas? i feel like im talking to my self i thought people usually chimed in with possible solutions.
edit: what is the black box inside dizzy that has 2 wires running from it?
Old Feb 3, 2007 | 09:54 AM
M2B4's Avatar
Default Re: (M2B4)
bump i need help....
Old Feb 4, 2007 | 05:36 AM
Default Re: (M2B4)
bump
nitewolf
12
Aug 21, 2009 10:08 AM
JLefevers
Apr 3, 2009 07:47 PM
90crvtec
Aug 19, 2005 07:19 PM
stealth civic
Jan 14, 2005 11:48 AM
shorty91
Jun 27, 2003 07:55 PM
