Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
ITR HPDE track alignment numbers
Old Feb 1, 2007 | 01:26 PM
ITR Motorsports's Avatar
Default ITR HPDE track alignment numbers
Hey, Have a bone stock ITR with 22k miles. Only thing on the car is 15x7 speedmaster wheels and Falken Azenis. All suspension components are in great shape (I was just under it).
Drive the car once a week to work. Not too worried about street tire wear. Car sees just as much track as street. I am killing the outer edges of the front tires. Probably looking for middle of the road spec as far as tame/aggressive. I do not want to make drastic changes. The stock setup works pretty darn good, but the Honda factory conservative understeer is getting expensive with tires...
I searched, but I think I may be the only guy with a stock ITR that is tracked regularly. Can someone give me a middle of the road spec and an aggressive spec for a stock ITR?
Thanks, JC
Old Feb 1, 2007 | 02:50 PM
Lo-Buck EF's Avatar
i'll let rob or will handle this one. they both track(ed) fairly stock Rs as far as suspension goes.
Old Feb 1, 2007 | 03:50 PM
TPB's Avatar
TPB
Default Re: (Lo-Buck EF)
If you have stock suspension arms, then you really have no front camber or caster adjustment, only toe. In the rear you can alter stock suspension camber with washers and toe with the compensator arm.
Out of interest, what cold pressures are you running your tires anyway?
Old Feb 1, 2007 | 05:21 PM
Track rat's Avatar
Default Re: (TPB)
Here's what I ran on my street/track Type R before it bacame a dedicated race car:
Front camber = 1.75 degrees neg
Rear camber = 1.0 degrees neg
Front toe = 1/16th out
Rear toe - O
I had Koni Yellows with 400lb front and 500lb rear springs. Skunk front "A" arms and Ingalls rear camber rods. This was a GREAT compromise street/track set up with no real tire wear issues.
Old Feb 1, 2007 | 05:43 PM
cjames235's Avatar
Default Re: (Track rat)
yea i run the same as ^^ with the only change in front camber i run less at -1.5
great for street/track........ i will add more camber once i have another car to drive but for now it is my daily
Old Feb 1, 2007 | 06:58 PM
Downey's Avatar
Default Re: (cjames235)
I just had our 96spec JDM ITR aligned lastweek @ Motorsport Techniques in Hayward, CA.
Its completly stock except for some HKS HyperMax coilovers. Everything elese, suspension wise is stock.
Front left
Camber = -1.9
Caster = 0.2 deg.
Toe = -.02
Front Right
Camber = -2.4
Caster = 0.1
Toe = -0.04
Total front toe = -0.05 (1/16th inch toe out)
Left Rear
Camber = -2.3
Toe = 0.00
Right Rear
Camber = -2.1
Toe = 0.01
Total toe = 0.01 (pretty much ZERO)
We have run this setup before and it works awesome for both track and street.
Old Feb 1, 2007 | 08:46 PM
rebo0t's Avatar
what about tire pressures and would these specs work well in an EG chassis? thanks
Old Feb 2, 2007 | 06:49 AM
Default Re: (TPB)
Thanks for the responses. My tire pressures depend on the track and the weather, but my cold baseline is 35 front, 33 rear, and adjust +/- one psi from there.
Old Feb 2, 2007 | 10:25 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">Here's what I ran on my street/track Type R before it bacame a dedicated race car:
Rear toe - O
Basically what I started on, but I used 1/8th total front toe out..
Old Feb 2, 2007 | 02:42 PM
Downey's Avatar
Default Re: (ITR Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the responses. My tire pressures depend on the track and the weather, but my cold baseline is 35 front, 33 rear, and adjust +/- one psi from there.</TD></TR></TABLE>
depending on ambient temp and track temps we vary our cold tire pressures between 25 and 30.
On a warm day i usualy run 27f 28r
Old Feb 2, 2007 | 08:21 PM
Track rat's Avatar
Default Re: (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
Basically what I started on, but I used 1/8th total front toe out..</TD></TR></TABLE>
Good point!
I vary toe based on the track. Long straights = less toe. Tight tracks = 1/8th or more toe. I ran 1/4 at VIR once just as an experiment. It turned like a ****! When I trimmed it back to 1/16th, it gained 6+mph on both straights!
PredatorGSR
Jun 27, 2015 02:32 PM
ericlee303
Feb 26, 2006 09:27 PM
01ITR#173DC2ning
Feb 14, 2005 08:52 PM
JM Performance
Apr 23, 2002 04:46 PM
