Need to makle an obd2 ingition work on a obd1 harness
Old Feb 1, 2007 | 11:41 AM
Yolandita's Avatar
Default Need to makle an obd2 ingition work on a obd1 harness
My friend has a 94 civic with stock D16 non vtec engine and his stock ignition is very damage, He only found an Obd2 ignition that only has one plug, the stock obd1 harness has 2 plugs, how can i make it work?
is there any wiring harness diagram on the net that could help me?
Old Feb 1, 2007 | 12:13 PM
fmrprojects's Avatar
Default Re: Need to makle an obd2 ingition work on a obd1 harness (Yolandita)
its all the same color match them up and connect them
Old Feb 1, 2007 | 12:14 PM
HondaPartsHero's Avatar
Technical Hero
Old Feb 1, 2007 | 12:18 PM
Yolandita's Avatar
Default Re: Need to makle an obd2 ingition work on a obd1 harness (HondaPartsHero)
thanks
Old Feb 1, 2007 | 01:53 PM
Yolandita's Avatar
one question...
my obd1 harness has 9 wires and the obd2 ignition has 7 wires.
it dosnt match with the diagram above.
Old Feb 1, 2007 | 02:47 PM
Technical Hero
https://honda-tech.com/zerothread?id=577638
Old Feb 1, 2007 | 04:42 PM
b16ferio's Avatar
just get an obd 2 clip for it and pull the pins on both clips. write down the colors on both sides of the clip accordingly, and just match whatever wires you wrote down. and maybe if there is an aftermarket dizzy there might be some diffrent colors. good luck buddy.
chadek86
Feb 3, 2009 10:45 AM
grodzef9
Jun 21, 2008 03:17 PM
advan414
Feb 25, 2008 02:28 PM
Cractos
Jul 26, 2005 10:47 PM
danxdan
Jun 9, 2005 04:46 PM
