Found water in spark plug tower
I was working on my car today and i was going to drive it for the first time since after the engine swap. I started the car up and idled fine and i let it warm up. after it warmed up I put it in reverse and it died. long story short....I pulled the spark plugs and in the number 4 cylinder spark plug tower there was water in it.
Im wondering if its a blown head gasket. It wasnt coolant in the cylinder, I smelt it and it smelled like hot water.
thanks
thanks
blow it out with compressed air. I would probably change the plugs too because that plug may want to rust now. I actually would change the wires too because they aren't really supposed to let water get by.
Edit: and regardless that wire is probably going to corrode now that it has been all wet and ****.
hatchback_al
15
Jul 21, 2004 02:15 AM
