B16a axle problem
Old May 17, 2002 | 01:16 PM
si foo's Avatar
Default B16a axle problem
Hey guy something's wierd about my axles. I swap a B16a in my 90 civic si, I'm using the halfshalf off a B16a2 and the axles off a 95 teg. It bolts on with no problem but when I tighten the bolt the wheels won't spin. Right now I loosen the bolt's just a little enuogh for the wheels to spin. Any idea? Is it ok for me to drive like this? I've punch the axle bolt I don't think it will fall off..........thanks
Old May 17, 2002 | 01:18 PM
EP3_05's Avatar
Default Re: B16a axle problem (si foo)
You need to pop the dust seals off each axle and pop the spacer ring out of each hub. I had to do that when I was using my 90-93 integra intermediate shaft and axles.
Old May 17, 2002 | 01:26 PM
Urban Business
Guest
Posts: n/a
Default Re: B16a axle problem (91civic)
SiShane
Aug 23, 2008 07:41 AM
integrawow
Jun 13, 2007 09:34 PM
BIGBLOCKEK
May 12, 2006 03:24 PM
RSA_Reno
Mar 10, 2004 11:05 PM
