How do i replace the mirror on the 5th Gen Honda Prelude.
If you are talking about your rear view mirror then you need to pop that plastic cover off from the over head map lights, just use something thin and pry it in there and it will just pop off. then use a phillips and remove the screws you see under there. That whole assembley will will come off and you will see how to put in back on from there
3dscott
Aug 22, 2009 08:28 PM
