Do I need a camber kit??...
Will I need a camber kit if I use eibach pro-kit springs They are approx 1.5" drop front/rear and I have stock 15" gsr rims. Also would I need to upgrade my stock shocks?? tia
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Camber kit is not NECESSARY but it will help. W/out one you'll just have some bad camber wear after a little while, and horrible after a while.
Stock shocks don't work so well with coilovers when they're lowered, even when they're at stock height. I have skunkworks and they're at about stock height, but my shocks bottom out over big bumps on freeways and such, and I imagine its a lot worse when it's lowered. If you're gonna get suspension and you aren't the typical coilovers-only driver, get the whole setup- coilovers, shocks, camber kit.
krysted9354
Suspension & Brakes
May 18, 2009 12:49 PM
exratedaccord93
Sep 8, 2006 06:32 AM
