Honda S2000 Honda S2000
Car died at startup.
Old Jan 31, 2007 | 03:04 PM
Easyslider01's Avatar
Default Car died at startup.
So ever since Ive had my s2000, when I start it up the rpms dip down and they go back up. It dosnt do it that bad but enough to notice it. Well today I started it up and when it dipped down, it went so far down that it died. I went to start it back up and it took a second to turn over but it did start. I still drove it to work, with my eyes on the rpms and I noticed at idle it stays a little under 1k. Was this just a freak thing or is it something I should get checked out?
Old Jan 31, 2007 | 03:39 PM
LAS2K's Avatar
Default Re: Car died at startup. (Easyslider01)
map sensor possibly. change of weather lately? try a map whack.
searh for it at http://www.s2ki.com
Old Feb 1, 2007 | 06:46 AM
Startrek's Avatar
Default Re: Car died at startup. (LAS2K)
Same thing happened to me but also when driving the engine shut off...I think it is due to weather change where I live and the extreme cold...I just replaced the battery good luck and I let you know if I continue having the problem
Also fill me in if the map sensor helps
Old Feb 1, 2007 | 07:06 AM
dcturbols's Avatar
For some reason when the engine is very cold it will sometimes die when you try and start it.
Happens to me, all you have to do is when you first start it watch the tach and keep it at 1500rpm or so for like 5 secs and when you let off the gas it will idle normally for warm-up.
Old Feb 1, 2007 | 09:50 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
i do that same as above. it's a common problem with the s2k. it basically tries to adjust to the weather change.
Old Feb 1, 2007 | 11:54 AM
Mike_C's Avatar
happens to me on extremely cold days as well. we're talking nights hovering around 10.
Old Feb 1, 2007 | 11:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Bumble-BEE)
feed the hamster before start up .. he doesnt have enough energy to turn the wheel...
nah seriouly now the location of the car plays a big effect because our ECU's are always learning..
aznfreakyguy
Jul 3, 2011 12:24 AM
midwesta
Jan 27, 2008 02:32 PM
imbrzyant
Dec 30, 2007 07:10 PM
daredeezy619
Feb 9, 2007 04:55 PM
JDMRACER689
Aug 19, 2006 09:39 AM
