What mounts do i need....? (already searched)
Old Jan 31, 2007 | 12:06 PM
SL0-hatch's Avatar
Default What mounts do i need....? (already searched)
I am planning on doing a GSR swap into a 1996-2000 civic hatch. I've got a totaled 98 integra gsr and need to know what mounts i need that will make the gsr motor fit into a 96+ civic hatch....will the stock GSR mounts fit?would the 98 gsr shift linkage also work with it?
Modified by 98IntegraGSRguy at 7:04 AM 2/1/2007
Old Jan 31, 2007 | 12:08 PM
philosofy1's Avatar
Default Re: What mounts do i need....? (98IntegraGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98IntegraGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on doing a GSR swap into a 1996-2000 civic hatch. I've got a totaled 98 integra gsr and need to know what mounts i need that will make the gsr motor fit into a 96+ civic hatch....will the stock GSR mounts fit?</TD></TR></TABLE>
the tranny, lower and rear mounts will work, the one you will have problems with is the driverside mount.
Old Jan 31, 2007 | 12:10 PM
turbociviccoupe's Avatar
Default Re: What mounts do i need....? (philosofy1)
and rear L bracket should be from a 00 si
Old Jan 31, 2007 | 12:14 PM
philosofy1's Avatar
Default Re: What mounts do i need....? (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">and rear L bracket should be from a 00 si</TD></TR></TABLE>
oh yeah, i forgot about that. good looking
Old Jan 31, 2007 | 12:16 PM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">and rear L bracket must be from a 00 si</TD></TR></TABLE>
fixxed
Old Jan 31, 2007 | 12:17 PM
VRD^sam's Avatar
you will need a B16 Dual Post mount, B16 Rear Bracket. you can use your stock Passenger top tranny mount...
Old Feb 1, 2007 | 06:04 AM
SL0-hatch's Avatar
what else would i need for the swap or would everything else fit:axles, shift linkage?
mr_munro
Dec 31, 2009 05:11 AM
Shaynepolevault
Aug 26, 2008 11:18 AM
boosted92hatch
10
May 28, 2006 09:23 AM
StreetRacnGsR
May 9, 2003 02:51 PM
