Transmission
Old Jan 31, 2007 | 11:38 AM
zmanecu's Avatar
Default Transmission
I was told the Transmission Control Module was the reason why most of the time now my 1992 Honda Accord EX was stuck in 1st and 3rd or 2nd and 4th gear, but I bought a New Transmission Control Module and it's doing the same thing. When I put it in it ran fine the next day it was back doing the same thing, so what could be the proble now? PLEASE HELP!!!
Modified by zmanecu at 12:55 PM 1/31/2007
Old Jan 31, 2007 | 05:47 PM
JDM_DC4_Fanatic's Avatar
Default Re: Transmission (zmanecu)
how does a transmission get stuck in 2 gears at once? you need to be a little more descriptive about this problem
Old Jan 31, 2007 | 06:40 PM
hondadude's Avatar
jumper the 2 pin connection then count the trans code 'D4' light flashes.
link;
http://members.troublecodes.ne...n.jpg
I'm paying good money for that webspace every month so you'd better check the link and repost here with a code!
To help you out some more; if you turn on the key the D4 light should come on as the system runs the internal check and then the light goes off.
Old Feb 1, 2007 | 04:30 PM
zmanecu's Avatar
Default Re: Transmission (hondadude)
I don't know.. it just does. It will be in park, but the light on the dash will show "D".
Any gear I move it to manually, that gear will light up and the "D" light will be lit.
Old Feb 1, 2007 | 04:32 PM
Homesickelian's Avatar
The D light is usually a code, when your not in that gear, and something needs to be fixed. Listen to what Hondadude said please...
Old Feb 1, 2007 | 04:35 PM
zmanecu's Avatar
I'll try that and see what happens... then i'll get back too you.
Oh yea, I did post the year of the car, it's a '92
thanks for you guys help.
Old Feb 1, 2007 | 04:48 PM
zmanecu's Avatar
I jumpered the 2pin connection like the picture showed and the "Check Engine" and the"D4" light stayed solid. Does this tell you anything or do I need to try something else.
Thanks
Modified by zmanecu at 6:25 PM 2/1/2007
Old Feb 2, 2007 | 05:46 PM
hondadude's Avatar
If you turn the key on and the 'D' light stays on, it probably is a bad TCU.
The 'D' light should come on for about 2 seconds while the TCU runs a self check then turn off.
Old Feb 3, 2007 | 07:42 AM
zmanecu's Avatar
I'm taking it that your refering to the Transmission Control Module under the passenger side carpet.
I replaced it.
Old Feb 3, 2007 | 10:50 AM
jennifercrabgirl's Avatar
I got a 90' Honda Accord that the sports gear comes on for no reason?I'll go to take off sometimes the sports gear come on and it'll move super slow.Do you think it's a trans prob or maybe the button short out??????
coolie2609
Jan 16, 2012 09:38 AM
jmayhem
Jul 7, 2010 06:26 AM
roonierobster
Jul 22, 2008 09:03 PM
eaglefighter
Jan 19, 2008 08:17 PM
hcic
Jun 7, 2007 07:27 PM
