5th Gen Prelude- Looking to purchase.
Old Jan 31, 2007 | 10:25 AM
tc's Avatar
tc
Default 5th Gen Prelude- Looking to purchase.
What are some things to look out for? Any preferable years? Any common problems/troubles? How are the SH's holding up?
Most of the one's I'm looking at have about 100k miles, so I don't want to get something that's going to require major maintenance/repairs soon.
Thanks!
Old Jan 31, 2007 | 11:04 AM
Wsteun's Avatar
I bought my 97 SH back in May with 109,015 on the odometer. I rolled 115K this month. Haven't had any issues with the car besides having to replace the thermostat.
Old Jan 31, 2007 | 11:32 AM
o-Shadowlude-o's Avatar
Default Re: 5th Gen Prelude- Looking to purchase. (tc)
I just bought a 98 SH about a month ago, i just rolled 91k. It runs great haven’t had any problems, nor any signs of problems. Timeing belt is in great shape, no leaking of any fluids, clutch doesnt slip at all. I hit V-tec every time at same time, motor runs strong and hard. No nocks, ticks of any sort. All in all I think buying my lude was a great deal, I don’t here to many bad things about them, i'm happy with mine .
Old Jan 31, 2007 | 11:43 AM
Honda4Life.'s Avatar
Just make sure the T-belt and H2O pump has been done alone with the auto tensioner. As long as the maint. has all been done you should be good. As for certain years, I prefer the 99-01.
Good luck in your hunt.
Mike (H4L)
Old Jan 31, 2007 | 11:46 AM
BB2H22's Avatar
The automatics have been known to have problems. I'd recommend getting a 5spd.
Old Jan 31, 2007 | 12:24 PM
tc's Avatar
tc
Default Re: (Honda4Life.)
So, 99-01, and no automatics.
When should the t-belt/water pump be changed? 90k?
Any extra maintenance or concerns with the SH's?
Thanks!
Old Jan 31, 2007 | 12:34 PM
vinuneuro's Avatar
Default Re: (tc)
The 5th gen's were unchanged 97-01, other than minor color differences, etc. Look at all model years.
Timing belt, water pump should be replaced around 90k. Other stuff that should be done around then: valve adjustment, brake fluid, coolant, transmission fluid, spark plugs/wires, distributor cap+rotor etc. The only maintenance regarding ATTS would be to replace the fluid (Honda ATF) every so often. Honda doesn't even mention a fluid change interval for it.
Usually a car that has been taken care of well will reflect in it's overall condition in/out, service records, etc. Personally, I would get a compression test done as well.
Good luck.
Old Jan 31, 2007 | 02:46 PM
RallyeSH's Avatar
I'll just be honest, buying a 97 SH was the best decision I ever made...
My friend is jealous, and he drives a Type R
my .02
Old Jan 31, 2007 | 08:56 PM
socalSH's Avatar
got 99 SH about 79k on it, runs great, just remember to check oil, a lot.
Old Oct 26, 2023 | 12:33 PM
Hirakuu's Avatar
Hey are preludes really burning that much oil? , Everybody seems to talk about it a lot. Also does the H22 have a good fuel economy? When i purchase mine i will jump from a 1.5L ( my daily ) to a 2.2L
Old Oct 26, 2023 | 08:06 PM
TimiK's Avatar
10 Year Member
Piston rings and cylinder walls are the weak point so when piston rings wear the oil burning is higher but even with those things healthy check your oil level regularly.
Fuel economy is not great in modern standards but depends how much you drive and how you drive. Mine is around 8l/100km straight driving outside cities without much accelerations
4drRacer
Nov 24, 2023 07:00 PM
fubar
Nov 22, 2003 03:41 PM
waterwagen23
Sep 29, 2003 03:26 PM
reno96teg
Apr 6, 2003 08:53 PM
liuman51086
Jan 7, 2003 05:04 PM
