Fuse Box Diagram (searched found nothing useful)
Old Jan 31, 2007 | 09:38 AM
Fezzie's Avatar
Default Fuse Box Diagram (searched found nothing useful)
ok i have a 90 sedan and i did a wire tuck while my car has no motor in it and to make it easier i took my dash off, ok and i unpluged the wired from my fuse box and taped them up to make it look cleaner (I had wires hanging near my pedals) so i need a diagram of where the wires go to the front and back of the fuse box under the dash, it would be great if someone can send me to a link or something cause i think i got it right but my windows wont work and when i turn my key all the lights in my cluster light up
Old Jan 31, 2007 | 01:04 PM
Fezzie's Avatar
Default Re: Fuse Box Diagram (fezzie)
anyone?
Old Jan 31, 2007 | 01:42 PM
sanimalp's Avatar
$cat /dev/urandom
you may already know this, but just in case..
the access panel that you have to remove below the steering wheel to view the fuse box *should* have the fuse diagram either printed on it, or on a plastic insert attached to the panel. thats half the puzzle. the other half can be found in the wiring section of the honda manual, and possibly a helms. there are pdf versions of the manual floating around here somewhere.. so check that out.
Old Jan 31, 2007 | 03:11 PM
doublethink's Avatar
Helms Manual has all those diagrams.
its someone every DIYer should own.
Old Jan 31, 2007 | 08:18 PM
Fezzie's Avatar
Default Re: Fuse Box Diagram (sanimalp)
ight ima try an find a helms online
TonyTheThaiger
Jan 18, 2012 01:16 AM
91EfRaCer
Oct 15, 2009 01:53 PM
tweek_boii
10
Sep 6, 2009 09:54 PM
misledyouth_is_back
Dec 30, 2003 02:59 PM
