Sticking E-brake?
my question is, when its cold outside (bellow 32 degrees f) and i release my e-brake the light doesnt go out, it still shows the big red anoying "brake" sign.
it only does it when its at or below 32 out and it goes away after the car is all warmed up.
is this common? or even something i should be worried about?
when you check your brake fluid level take the top off the reservoir and look at the actual fluid level,; many people are fooled by the 'scum line' they see from the outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak »</TD></TR><TR><TD CLASS="quote">alright i will check that and see how it looks.
assuming the fluid is full, what else could it be?</TD></TR></TABLE>
check it then we will decide how much more we want to play with your skull
ROFLMAO
ROFLMAO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">
ROFLMAO</TD></TR></TABLE>
what haha.
if its full check to see if the brakes are dragging. they might be sticking. also, you could just not use it, i had a jetta and VW said to me, "don't pull the ebrake when its cold, it makes the brakes stick. just leave it in gear."
what haha.
no luck, the fluid level appears fine, so i think it might just be a stick switch somwhere.
i say this because i was driving home today and the whole way it was not on, i get off the highway and it turns on (ebrake light) so im not sure. i cant imagine its anything big.
i wasnt sure if there was anything to look at but like i said fluid level looks good, and the pads dont appear to be dragging.
the actual switch on the parking lever is just a ground strap, something could have fallen down in there and be grounding the metal tab; you might be able to see it with a strong flashlight looking in the parking brake lever slot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak »</TD></TR><TR><TD CLASS="quote">no luck, the fluid level appears fine, so i think it might just be a stick switch somwhere.</TD></TR></TABLE>
Scum line on the reservoir can fool ya; it's better to remove the cap and look.
Z7
10
Aug 6, 2006 01:17 PM
philosofy1
Apr 25, 2005 11:39 AM
