type r suspension
Old Jan 31, 2007 | 06:49 AM
kadeem71's Avatar
Default type r suspension
What's so good about typr r suspension?
What makes them dfferent from any other suspension?
Old Jan 31, 2007 | 07:52 AM
Doespike's Avatar
Default Re: type r suspension (kadeem71)
Simple answer: On an Integra Type R, the ITR suspension is finely tuned and balanced. On other vehicles, it probably won't be quite so perfect.
Old Jan 31, 2007 | 08:23 AM
CW-ITR's Avatar
It took Honda two years to developed the TypeR from the base GSR. So, the spring rate and the shock dampening work harmony together which means no harsh ride like most after market parts and handle much better than the average OEM parts
Old Jan 31, 2007 | 08:29 AM
MatrixShark's Avatar
Awesome control, perfect balance, and just the right amount of oversteer when you need it.
Old Jan 31, 2007 | 08:37 AM
Amped's Avatar
Default Re: (MatrixShark)
Its so finly tuned that if you make the vehicle lighter in any way it wont handle aswell. Its perfectly balanced. You would have to get a stiffer spring rate if you remove weight from the vehicle. Honda engineers suggest not doing anything to try and improve it unless you get it pro tuned.
Old Jan 31, 2007 | 09:32 AM
itrdave's Avatar
Default Re: (Amped)
Best handling FWD car ever to come out of an automotive factory. That said -you really have to get it past 7/10 before the benefits become obvious.
meka0408
14
Mar 6, 2013 04:47 AM
slowassR
27
Feb 21, 2003 02:59 PM
Matt Groove
Oct 15, 2002 07:16 AM
Ausmith
Feb 5, 2002 09:31 AM
Ricehornet
Jun 27, 2001 03:15 AM
