How to seal a Moroso oil pan properly?
My baffled steel oil pan is dropping oil while the engine is running in every 2 seconds.
We are using stock rubber gasket + locktight paste.
How the hell I can prevent oil dropping? I heard it is a common problem with Moroso...
We are using stock rubber gasket + locktight paste.How the hell I can prevent oil dropping? I heard it is a common problem with Moroso...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koczeka »</TD></TR><TR><TD CLASS="quote">
How the hell I can prevent oil dropping? I heard it is a common problem with Moroso...</TD></TR></TABLE>
I just heard the same thing the other night at work. If no one has an answer I will ask the guy who had one how he fixed his on Thursday when I go back to work.
I use a rear sumped moroso and it only leaked at the front #1 side corner. When I had it off to look at the bottom end, I just added a dab of silicone sealer to the oem gasket and threw it back on and have no problems with it.
um, theres some extensive tq pattern i know. i forgot it, but i know i had to help a friend that blew his motor. it wasnt me, i was the bitch who knew everything. The box wasnt moroso so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finger Lickin’ good »</TD></TR><TR><TD CLASS="quote">um, theres some extensive tq pattern i know. i forgot it, but i know i had to help a friend that blew his motor. it wasnt me, i was the bitch who knew everything. The box wasnt moroso so.
Was that written in Engrish??!?!?
Are you sure it's not the 1/2" NPT pipe plug for the oil return? I had to go back and Hondabond the plug before it stopped weeping.
i'm using the steel pan and don't have any problems. the mating surface was pretty rough; i dremeled down a few bumps that were sticking up and use a bunch of hondabond to seal the dips. with about 700 miles on it i don't have any leaks yet.
I've been slowly getting to each leak. The pan probably leaks from every mating surface and port plug.
The oil drain port leaked. I tightened it a little more and it stopped. But, I always have to go back in a couple of days to check it and retighten if necessary.
The turbo oil drain was a big leaker. Fixed that by installing the 1/2" NPT to -10AN adapter with Hondabond and capping it with a -10AN flare cap. Fixing that leak kept a large portion of oil off the bottom of the pan.
The Mugen oil pan I had was perfect....except I didn't want to bastardize a $250 pan with a bunch of weld-on adapters. I'm kind of wishing I had now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">RTV is your friend. Try the grey.</TD></TR></TABLE>
I have found the problem lies int the nipples between the holes being too large. They squish the seal out of form and makes it leak. Solution....... I used a Felpro Gasket and it sealed perfectly. The seem to me made of silicone not rubber and do not loose their shape as easily as the OEM units.
+ new gasket + a little hondabond solved the probplem.
