mini me swap HELP IM NEW TO THIS SITE....
hey guys/girls...i have a 1990 civic CX...and im doin a d16z6 mini me swap to it but theres alot of things that im have troubles with can you guys help me out please!!! i basically need a step by step guid on how the hell to do this properly and what i need to do the swap..and woud it be better if i get the d16z6 wiring harness...these are all of the parts i currently have for the swap...
-d16z6 head
-jdm d15b vtec ecu
-vtec soleniod
hoeslty somebody please help me...i have no idea what im doing...
-d16z6 head
-jdm d15b vtec ecu
-vtec soleniod
http://crx.honda-perf.org/arti....html
That's a good how to.
Most of the questions you have should be answered by that. If they're not, reply here or use the search (preferably search).
convert to obd1,run the wires for vtec,convert to mpfi,
you can do this **** yourself or send out your harness and get it back ready to plug and play..
if you want to do it yourself look here obd0-obd1 vtec http://www.pgmfi.org/twiki/bin...-OBD1
Could you not just use the harness and ecu from a d16z6 on the mini-me swap straight up? In other words could you unplug the existing harness and ecu, perform the swap and then just use the untampered d16z6 harness and ecu (granted that you have gotten a d16z6 intake manifold as well)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkguitar »</TD></TR><TR><TD CLASS="quote">Could you not just use the harness and ecu from a d16z6 on the mini-me swap straight up? In other words could you unplug the existing harness and ecu, perform the swap and then just use the untampered d16z6 harness and ecu (granted that you have gotten a d16z6 intake manifold as well)?</TD></TR></TABLE>
no,,that harness wont plug into our cars without alot of mods,,its always easier to use the original harness and modify it...also the ecu he has now is better then the p28 cause afterall he has a 1.5 sohc vtec not a 1.6 sohc vtec so the ecu should run his motor damn near perfect
the code on the vtec ecu is a po8...is that i good ecu or no? cuz i was told that it will work and i payed good money for this 1...lemme no
AND THANX ALL OF YOU FOR YOUR SUPPORT
