check engine light
Old Jan 30, 2007 | 06:44 PM
1fast ek's Avatar
Default check engine light
after swapping a ls motor in my 96 ek coupe i keep getting a check engine light, the code is p1259 manufacter specific code . whats that
Old Jan 30, 2007 | 06:47 PM
Eran's Avatar
HT White Ops
You must be using the wrong ECU, because 1259 is for VTEC Malfunction ...
Old Jan 30, 2007 | 06:57 PM
1fast ek's Avatar
Default Re: (Eran)
i am using a 96 ls ecu , the plug for the vtec is just hanging. will that cause the car to miss and not rev out
Old Jan 30, 2007 | 07:01 PM
sicones's Avatar
Default Re: (1fast ek)
whats the number on the side of the ECU?
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fast ek &raquo;</TD></TR><TR><TD CLASS="quote">i am using a 96 ls ecu , the plug for the vtec is just hanging. will that cause the car to miss and not rev out</TD></TR></TABLE>
Then you obviously have no idea what you're talking about.
You should not have VTEC.
So either you have the wrong ECU and wiring harness, or you don't have an LS motor (B18B1).
And yes, leaving plugs hanging is a problem.
Old Jan 30, 2007 | 07:02 PM
EJgsr's Avatar
Default Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">whats the number on the side of the ECU?</TD></TR></TABLE>
or whats it look like on the inside... i have seen cases switched out...
scspeed
Aug 8, 2008 03:27 PM
nicko360
Oct 27, 2007 09:27 AM
ITRiWISH
11
Aug 27, 2007 05:24 PM
kuja396
Mar 15, 2007 10:17 PM
kidrolla
Jan 26, 2005 07:12 PM
