Help? Compression ratio question/ on build
well i put my itr bottom end back together with all new bearings, oil pump, same type r rods w/ new ctr's on them. I have a new head build with stage 2 cams, and a stock set of new type r valves. i ordered a cometic head gasket 65 thousands. I am expecting the build to be back at 11.4-11.6.1 compression. Are my calculations right i even used the dome of the piston.
Alright cool, just making sure you weren't trying to use a .0065" headgasket... That would throw CR WAAAAAAAY too high, over 13.5:1.
But as you previously stated, with .065" headgasket (Ticker than OEM 3-Layer), it will be just around 11.4:1-11.5:1. Perfect CR for a mild build.
red civic standard
Dec 12, 2005 08:49 AM
